Since quic does not seem to have the wanted effect I wanted to experiment a bit under what conditions it cannot connect. If I’m reading the following log correctly it does not even seem to try it in my case since it connects to a wrong device via tcp (which has a port forward and is behind the same NAT). After disabling the forward it instantly connects via quic.
[NGJDQ] 2019/07/12 20:48:06.220233 api.go:618: INFO: Enabled debug data for "connections"
[NGJDQ] 2019/07/12 20:48:20.883773 api.go:618: INFO: Enabled debug data for "dialer"
[NGJDQ] 2019/07/12 20:48:50.925673 service.go:343: DEBUG: Reconnect loop
[NGJDQ] 2019/07/12 20:48:50.925847 service.go:380: DEBUG: Reconnect loop for CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL [quic://80.xxx.xxx.xxx:1024 quic://80.xxx.xxx.xxx:22000 quic://80.xxx.xxx.xxx:24000 quic://[2003:xxxx]:22000 quic://[2003:xxxx]:24000 tcp://80.xxx.xxx.xxx:22000 tcp://[2003:xxxx]:22000]
[NGJDQ] 2019/07/12 20:48:50.931211 structs.go:224: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://80.xxx.xxx.xxx:22000 prio 10
[NGJDQ] 2019/07/12 20:48:50.931275 structs.go:224: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://[2003:xxxx]:22000 prio 10
[NGJDQ] 2019/07/12 20:48:50.966645 tcp_dial.go:48: DEBUG: Dial (BEP/tcp): setting traffic class: setsockopt: protocol not available
[NGJDQ] 2019/07/12 20:48:52.744545 structs.go:229: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://80.xxx.xxx.xxx:22000 success: 192.168.1.12:44084-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[NGJDQ] 2019/07/12 20:48:52.744662 service.go:861: DEBUG: connected to CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL 10 using 192.168.1.12:44084-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 10
[NGJDQ] 2019/07/12 20:48:52.744772 service.go:380: DEBUG: Reconnect loop for RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN [quic://80.xxx.xxx.xxx:22000 quic://80.xxx.xxx.xxx:24000 quic://[2003:yyyy]:22000 quic://[2003:yyyy]:24000 tcp://80.xxx.xxx.xxx:22000 tcp://[2003:yyyy]:22000]
[NGJDQ] 2019/07/12 20:48:52.748174 structs.go:224: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://80.xxx.xxx.xxx:22000 prio 10
[NGJDQ] 2019/07/12 20:48:52.748221 structs.go:224: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://[2003:yyyy]:22000 prio 10
[NGJDQ] 2019/07/12 20:48:52.772236 service.go:257: INFO: Connection from NOT-WANTED-DEVICE at 80.xxx.xxx.xxx:22000 (tcp-client) rejected: device is ignored
[NGJDQ] 2019/07/12 20:48:52.778160 tcp_dial.go:48: DEBUG: Dial (BEP/tcp): setting traffic class: setsockopt: protocol not available
[NGJDQ] 2019/07/12 20:48:55.193135 structs.go:229: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://80.xxx.xxx.xxx:22000 success: 192.168.1.12:44090-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[NGJDQ] 2019/07/12 20:48:55.193297 service.go:861: DEBUG: connected to RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN 10 using 192.168.1.12:44090-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 10
[NGJDQ] 2019/07/12 20:48:55.193393 service.go:471: DEBUG: sleep until next dial 1m0s
[NGJDQ] 2019/07/12 20:48:55.220227 service.go:257: INFO: Connection from NOT-WANTED-DEVICE at 80.xxx.xxx.xxx:22000 (tcp-client) rejected: device is ignored
[NGJDQ] 2019/07/12 20:49:00.931899 structs.go:227: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://[2003:xxxx]:22000 error: dial tcp [2003:xxxx]:22000: i/o timeout
[NGJDQ] 2019/07/12 20:49:00.932049 service.go:864: DEBUG: discarding 0 connections while connecting to CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL 10
[NGJDQ] 2019/07/12 20:49:02.748924 structs.go:227: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://[2003:yyyy]:22000 error: dial tcp [2003:yyyy]:22000: i/o timeout
[NGJDQ] 2019/07/12 20:49:02.749100 service.go:864: DEBUG: discarding 0 connections while connecting to RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN 10
[NGJDQ] 2019/07/12 20:49:55.193916 service.go:343: DEBUG: Reconnect loop
[NGJDQ] 2019/07/12 20:49:55.337617 service.go:380: DEBUG: Reconnect loop for CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL [quic://80.xxx.xxx.xxx:1024 quic://80.xxx.xxx.xxx:22000 quic://80.xxx.xxx.xxx:24000 quic://[2003:xxxx]:22000 quic://[2003:xxxx]:24000 tcp://80.xxx.xxx.xxx:22000 tcp://[2003:xxxx]:22000]
[NGJDQ] 2019/07/12 20:49:55.340640 structs.go:224: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://80.xxx.xxx.xxx:22000 prio 10
[NGJDQ] 2019/07/12 20:49:55.340685 structs.go:224: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://[2003:xxxx]:22000 prio 10
[NGJDQ] 2019/07/12 20:49:55.381732 tcp_dial.go:48: DEBUG: Dial (BEP/tcp): setting traffic class: setsockopt: protocol not available
[NGJDQ] 2019/07/12 20:49:57.174254 structs.go:229: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://80.xxx.xxx.xxx:22000 success: 192.168.1.12:44142-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[NGJDQ] 2019/07/12 20:49:57.174438 service.go:861: DEBUG: connected to CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL 10 using 192.168.1.12:44142-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 10
[NGJDQ] 2019/07/12 20:49:57.207200 service.go:257: INFO: Connection from NOT-WANTED-DEVICE at 80.xxx.xxx.xxx:22000 (tcp-client) rejected: device is ignored
[NGJDQ] 2019/07/12 20:49:57.223813 service.go:380: DEBUG: Reconnect loop for RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN [quic://80.xxx.xxx.xxx:22000 quic://80.xxx.xxx.xxx:24000 quic://[2003:yyyy]:22000 quic://[2003:yyyy]:24000 tcp://80.xxx.xxx.xxx:22000 tcp://[2003:yyyy]:22000]
[NGJDQ] 2019/07/12 20:49:57.228402 structs.go:224: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://80.xxx.xxx.xxx:22000 prio 10
[NGJDQ] 2019/07/12 20:49:57.228726 structs.go:224: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://[2003:yyyy]:22000 prio 10
[NGJDQ] 2019/07/12 20:49:57.273602 tcp_dial.go:48: DEBUG: Dial (BEP/tcp): setting traffic class: setsockopt: protocol not available
[NGJDQ] 2019/07/12 20:49:59.074320 structs.go:229: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://80.xxx.xxx.xxx:22000 success: 192.168.1.12:44146-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[NGJDQ] 2019/07/12 20:49:59.074482 service.go:861: DEBUG: connected to RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN 10 using 192.168.1.12:44146-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 10
[NGJDQ] 2019/07/12 20:49:59.074583 service.go:471: DEBUG: sleep until next dial 1m0s
[NGJDQ] 2019/07/12 20:49:59.101366 service.go:257: INFO: Connection from NOT-WANTED-DEVICE at 80.xxx.xxx.xxx:22000 (tcp-client) rejected: device is ignored
[NGJDQ] 2019/07/12 20:50:05.341291 structs.go:227: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://[2003:xxxx]:22000 error: dial tcp [2003:xxxx]:22000: i/o timeout
[NGJDQ] 2019/07/12 20:50:05.341530 service.go:864: DEBUG: discarding 0 connections while connecting to CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL 10
[NGJDQ] 2019/07/12 20:50:07.229343 structs.go:227: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://[2003:yyyy]:22000 error: dial tcp [2003:yyyy]:22000: i/o timeout
[NGJDQ] 2019/07/12 20:50:07.229514 service.go:864: DEBUG: discarding 0 connections while connecting to RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN 10
[NGJDQ] 2019/07/12 20:50:59.074804 service.go:343: DEBUG: Reconnect loop
[NGJDQ] 2019/07/12 20:50:59.074938 service.go:380: DEBUG: Reconnect loop for CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL [quic://80.xxx.xxx.xxx:1024 quic://80.xxx.xxx.xxx:22000 quic://80.xxx.xxx.xxx:24000 quic://[2003:xxxx]:22000 quic://[2003:xxxx]:24000 tcp://80.xxx.xxx.xxx:22000 tcp://[2003:xxxx]:22000]
[NGJDQ] 2019/07/12 20:50:59.078153 structs.go:224: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://80.xxx.xxx.xxx:22000 prio 10
[NGJDQ] 2019/07/12 20:50:59.078364 structs.go:224: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://[2003:xxxx]:22000 prio 10
[NGJDQ] 2019/07/12 20:50:59.123511 tcp_dial.go:48: DEBUG: Dial (BEP/tcp): setting traffic class: setsockopt: protocol not available
[NGJDQ] 2019/07/12 20:51:01.231781 structs.go:229: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://80.xxx.xxx.xxx:22000 success: 192.168.1.12:44202-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[NGJDQ] 2019/07/12 20:51:01.231909 service.go:861: DEBUG: connected to CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL 10 using 192.168.1.12:44202-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 10
[NGJDQ] 2019/07/12 20:51:01.232016 service.go:380: DEBUG: Reconnect loop for RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN [quic://80.xxx.xxx.xxx:22000 quic://80.xxx.xxx.xxx:24000 quic://[2003:yyyy]:22000 quic://[2003:yyyy]:24000 tcp://80.xxx.xxx.xxx:22000 tcp://[2003:yyyy]:22000]
[NGJDQ] 2019/07/12 20:51:01.236165 structs.go:224: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://80.xxx.xxx.xxx:22000 prio 10
[NGJDQ] 2019/07/12 20:51:01.236372 structs.go:224: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://[2003:yyyy]:22000 prio 10
[NGJDQ] 2019/07/12 20:51:01.268311 service.go:257: INFO: Connection from NOT-WANTED-DEVICE at 80.xxx.xxx.xxx:22000 (tcp-client) rejected: device is ignored
[NGJDQ] 2019/07/12 20:51:01.276445 tcp_dial.go:48: DEBUG: Dial (BEP/tcp): setting traffic class: setsockopt: protocol not available
[NGJDQ] 2019/07/12 20:51:03.022376 structs.go:229: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://80.xxx.xxx.xxx:22000 success: 192.168.1.12:44206-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305
[NGJDQ] 2019/07/12 20:51:03.022549 service.go:861: DEBUG: connected to RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN 10 using 192.168.1.12:44206-80.xxx.xxx.xxx:22000/tcp-client/TLS1.2-TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305 10
[NGJDQ] 2019/07/12 20:51:03.022682 service.go:471: DEBUG: sleep until next dial 1m0s
[NGJDQ] 2019/07/12 20:51:03.050110 service.go:257: INFO: Connection from NOT-WANTED-DEVICE at 80.xxx.xxx.xxx:22000 (tcp-client) rejected: device is ignored
[NGJDQ] 2019/07/12 20:51:09.078928 structs.go:227: DEBUG: dialing CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL tcp://[2003:xxxx]:22000 error: dial tcp [2003:xxxx]:22000: i/o timeout
[NGJDQ] 2019/07/12 20:51:09.079043 service.go:864: DEBUG: discarding 0 connections while connecting to CKHPUD6-SYDTIOZ-Z2ZUZYL-2QZVZ65-7OD6LHS-CGXE6F3-R6QW6H7-XU35MQL 10
[NGJDQ] 2019/07/12 20:51:11.237067 structs.go:227: DEBUG: dialing RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN tcp://[2003:yyyy]:22000 error: dial tcp [2003:yyyy]:22000: i/o timeout
[NGJDQ] 2019/07/12 20:51:11.237213 service.go:864: DEBUG: discarding 0 connections while connecting to RYYMNZO-FM4MI6X-AKIKQBA-BTMR7ZI-RBGJ45G-DFT4EYK-YVAQELM-B473YAN 10
