Since the -no-upgrade argument has disappeared from the cli I’m not sure what is the proper way to prevent syncthing from upgrading automatically. I inspected the source code a little bit and it seems if I pass an empty value in the -upgrade-to argument it has the same result. Could you confirm this? If no, how can I achieve this?
Sorry, I don’t use the GUI at all, since I wrote an own frontend on the top of the ST. I need to adjust this from the cli or through the REST API. But I guess if there is such an option then it’s viable through the REST API. I’ll do the homework!
Okay, now I see that there is an “upgrades” config parameter and by setting that I can achieve the desired result. However I cannot find anything about it in the latest docs. Should I send a PR or will you fix it?
