Hi, as all my systems now have SSD system drives where the constant access due to database maintenance is not a problem any more, I have finally moved from Resilio Sync to Syncthing.
Besides the small system SSDs on which the Syncthing home folder resides, the computers have HDDs for data. Most of the time, nothing is read or written so I want the HDDs to sleep as much as possible.
If I read everything correctly, there are 4 sources of disk access in Syncthing:
(1) Database maintenance
This is kind of annoying, but not a problem any more since I have the home folder on SSD.
(2) Data on remote device has changed and must be written to the local disk
No-brainer. Required.
(3) Folder Rescan
Leaving Folder Rescan enabled is advised in the docs (which makes sense). My first thought was to use a reasonably long interval (like 100 days) and be fine with a forced spinup every 100 days. However, the actual scan interval would be something between 75 and 125 days (3/4…5/4) per folder, so it will probably happen that if I have 20 folders, each would be scanned after spinup on a different day. This is not what I want.
So in my opinion the best option would be to create a cronjob or systemd timer which fires a curl -X POST -H X-API-Key:yourapikey http://127.0.0.1:8384/rest/db/scan
for all folders, right? In this case everything would be scanned one after the other (I have Max Folder Concurrency = 1) which is what I want.
(4) Versioning Cleanup
According to this commit, versioner cleanup is run on (after) the regularly scheduled scan. It doesn’t run on the various forced or triggered scans.
However, I currently do not fully understand this and its relationship with the per-folder configurable Cleanup Interval. My thought: The Cleanup Interval will tell when a cleanup is required, but the actual cleanup will be triggered by the scan? For example:
- Cleanup Interval: 1d, Rescan Interval: 30d: Will the cleanup be triggered every 1d independently or every 30d by the rescan?
- Cleanup Interval: 30d, Rescan Interval: 1d: Will the cleanup be triggered on every daily scan or only after 30d?
Will the cleanup never trigger if I disable the folder rescan and instead start it via API (see (3))?
