best Backup Syncthing method?
Hi, on a Win 10 with Synctrayzor is this the best backup method?
Backup config.xm, cert.pem and key.pem Replace in the new installation in C:\Users\xxx\AppData\Local\Syncthing
Does this work? Has anyone tested this?
What you listed is correct for Syncthing, but you may also want to back SyncTrayzor’s config up as well.
Thanks, what file is that?
Please check https://github.com/GermanCoding/SyncTrayzor#what-will-synctrayzor-do-to-my-system.
Also for backups specifically: GitHub - GermanCoding/SyncTrayzor: Windows tray utility / launcher for Syncthing (v2 continued)
SyncTrayzor’s config isn’t hugely important (it’s fairly quick to setup from scratch in most cases), but you can backup it as well if you prefer.
