Avoiding data loss
People suffering data loss because of misconfiguration, misunderstanding or hardware oddities are a recurring, if infrequent, feature here and on the issue tracker. For some of us we’re wise to things going wrong and/or dropping databases when we were young and foolish (listen, it was only a single site’s entire accounts data, OK? they had five other sites), but it’s not really right for us to say “you should have a backup” and wish them luck.
What do folk think of a first-time, very brief prompt that succinctly warns people about the possibility of data loss? Would it have helped previous victims, and prevent some future ones? Would the minor, one-off irritation be worth it? Should it force people to type “YES OK I GET IT I PROMISE I HAVE BACKUP” before being able to use syncthing?
If you’ve been a victim - or nearly been a victim - would this have saved your data?
I imagine it being a config directive which experienced users could just set to “true” when we generate our configurations, because we definitely have backups already. We definitely test them and know they work. Definitely.
My younger self would have just clicked yes, ignoring everything. My older self actually has backups and would also click yes.
“Why should I test my backups? They’ve never worked to begin with…”
Perhaps a link to “read more” about effective backup and/or some pitfalls of running Syncthing without a backup? I suspect its partly a failure of imagination in first-time users – “its just copying files between two computers, how can it possibly hose all my files… oh no!”
Someone should write/do something…
