Automating synthing functions (add device, folder, etc...)
I want to automatically add devices and folders. We use secure messaging and want to request additions and automatically add them. I know the system config - but the GUI must use something different. Can you enlighten me on how this can be done?
The GUI uses the system/config endpoint.
so basically we have to load the entire config file make the updates and post them back out?
Yep
This may be stupid - but can we pause syncthing - directly read and write the config - then continue? or do we need to use the api to rewrite it?
You can of course change the config file after shutting down syncthing, but doing it via the API is generally preferable.
by using the api - will syncthing recognize the changes immediately
never mind - it was in the documentation - Thanks for your help
