I removed the index database on one of my synched nodes running syncthing 14.29 because of corruption in the DB.
After rebuilding the index I got more then 50000 sync conflicts.
I know that most of them are false alarms (file and conflict file being identical), but there are some files where I know that there is a legitimate conflict. The problem is, I don’t know exactly where. Though I can probably remove more than half of the conflicts without problems that leaves still too many for checking manually.
Is there a fast way to remove the conflict files for the cases where the files are identical and leaving only real conflicts?
Is there maybe an option I’m not aware of or a tool?
For example, the following screenshot shows Python files with conflicts. I’ve never touched those files after the initial copy in 2013. Files and conflict files are identical.
That’s a bug. Which doesn’t help answer your original question. I guess you need some script that compares contents and removes the spurious conflict files when the content matches. Syncthing can’t do this, unfortunately.
