I have Syncthing installed on my QNAP NAS and on my phone.
Everything works if I am in my wireless network. But as soon as I disable wifi on my phone, the phone can’t reach the QNAP anymore.
On my phone I edited the QNAP device, entered the following address ip:22000 and on my router I forwarded port 22000 to the nas.
But the GUI on my phone and QNAP says disconnected.
Am I missing something?
edit: I use the newest beta version on Android.
Are you forwarding the same port to the same port? I also would suggest trying to forward something else, such as a webserver to see if forwarding on the router really works.
Yes 22000 to 22000. And I already have different port forwarding rules that are working (QNAP Webinterface, OpenVPN Server).
Check if you can connect to that port from outside with openssl s_client
`Loading 'screen' into random state - done
CONNECTED(00000138)
depth=0 CN = syncthing
verify error:num=18:self signed certificate
verify return:1
verify error:num=21:unable to verify the first certificate
verify return:1
write:errno=10054
SSL-Session:
Protocol : TLSv1.2
Cipher : ECDHE-RSA-AES256-SHA
Session-ID:
Session-ID-ctx:
Master-Key:
Key-Arg : None
PSK identity: None
PSK identity hint: None
SRP username: None
Start Time: 1449297144
Timeout : 300 (sec)
Verify return code: 21 (unable to verify the first certificate)`
I just set up everyting from scratch and its working now
