Is it correct to say that Syncthing for Android lacks the ability to move and rename files and directories?
Seemingly any attempt to perform such operations remotely, places a copy of the files into .stversions on the Android device, when I have “simple file versioning” enabled.
I wouldn’t mind so much having to delete all the duplicated files from .stversions, but they will result in confusion if I ever need to recover an accidentally deleted file.
That indeed seems to be the case, but I don’t think it’s got anything to do with Android. I can see the very same behaviour in Windows. I don’t believe there’s any way to work around it unless you set up a custom script to be used with external versioning. Not sure how usable external versioning itself is in Android though.
After thinking about the phenomenon a bit more, and playing with the behavior when renaming files…It occurs to me that this is probably not a bug, but a feature: It provides versioning of files’ names in addition to the mtime and contents! Actually rather thoughtful of the developers to include that, even if it can be a bit cumbersome.
