Android remote devices still show up as scanning
My host pc shows up as up to date for the shared folder as well the remote devices on the pc.
But on each remote android device it shows scanning still for many hours. Is this a bug? Im not sure what else to do aside from removing the folder on the remote devices clearing cache etc. And reset database and re add the devices to my host pc. Nothing seems to work.
188GB is a lot of data. I think you just need more patience. :slight_smile:
But its already finished per my image. 188/188.
Oh, yes. My bad. Sorry. I don’t know why.
Is there anything I should try?
Try pausing all devices on the device with the stuck scanning, if it is still stuck.
You mean pause on the device that has the issue or pause on the host device on that remote device?
Preferably the former, but either should work.
The goal is to disconnect all devices from the Android, because there is a bug that overloads the filesystem (and that causes significant slowdowns) when you’re pushing data to the cluster on Android. The bug has been fixed but there isn’t a release yet with the bugfix.
I think its working after just letting it stay on overnight but ill check again now.
