I’ve just tried using the current main
(with the latest CC patch) but there doesn’t seem to be any difference.
> Task :syncthing:checkPython
Using python 3.10.5 from C:\Users\User\AppData\Local\Programs\Python\Python310 (python)
Couldn't get final path for handle 0x178c, error code: 1
> Task :syncthing:buildNative
Caught exception: Couldn't resolve final path of, error = 1: R:\syncthing\syncthing-android
[python] python -u ./build-syncthing.py
Building syncthing for arm
Notice: Next generation GUI will not be built; see --with-next-gen-gui.
# github.com/syncthing/syncthing/cmd/syncthing
C:\Program Files\Go\pkg\tool\windows_amd64\link.exe: running R:\commandlinetools-win-9123335_latest\ndk\23.2.8568313/toolchains/llvm/prebuilt//windows-x86_64/bin/armv7a-linux-androideabi21-clang failed: exit status 1
ld: error: cannot open output file $WORK\b001\exe\a.out: Function not implemented
clang: error: linker command failed with exit code 1 (use -v to see invocation)
exit status 2
exit status 1
Traceback (most recent call last):
File "R:\syncthing\syncthing-android\syncthing\build-syncthing.py", line 101, in <module>
subprocess.check_call(
File "C:\Users\User\AppData\Local\Programs\Python\Python310\lib\subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['go', 'run', 'build.go', '-goos', 'android', '-goarch', 'arm', '-cc', 'R:\\commandlinetools-win-9123335_latest\\ndk\\23.2.8568313/toolchains/llvm/prebuilt//windows-x86_64/bin/armv7a-linux-androideabi21-clang', '-pkgdir', 'R:\\syncthing\\syncthing-android\\syncthing\\gobuild\\go-packages\\arm', '-no-upgrade', 'build']' returned non-zero exit status 1.
> Task :syncthing:buildNative FAILED
FAILURE: Build failed with an exception.
This is all done in a completely clean build environment that I set up just yesterday without re-using anything from anywhere else, i.e. both syncthing-android, SDK, NDK, etc. were downloaded from scratch, so I think the build is as clean as it can be , unless I’m missing something very obvious here.
I’m not sure what’s up with the Couldn't get final path for handle 0x13a4, error code: 1
error though. It wasn’t there before with the older version of Gradle.
Edit:
I’ve managed to find https://stackoverflow.com/questions/54800309/linker-error-during-so-file-creation-error-function-not-implemented. Also not sure if actually related, but the answer does talk about the problem only happening “on Windows when doing a debug build”.
