You’ll have to switch compiler and linker.
https://developer.android.com/ndk/guides/other_build_systems
Ok, I got this output. Anything useful or a hint in there?
(Too big for the forum, 34 K output) → # runtime/cgoAndroid (7284624, based on r416183b) clang version 12.0.5 (https: - Pastebin.com
Result:
go build -v -tags noupgrade -trimpath -ldflags -w -X github.com/syncthing/syncthing/lib/build.Version=v1.18.2 -X github.com/syncthing/syncthing/lib/build.Stamp=1629655487 -X github.com/syncthing/syncthing/lib/build.User=XXX -X github.com/syncthing/syncthing/lib/build.Host=XXX -X github.com/syncthing/syncthing/lib/build.Tags=noupgrade github.com/syncthing/syncthing/cmd/syncthing
I’ve also tried to modify “build.go” from …
args := []string{"build", "-v"}
to
args := []string{"build", "-v -x"}
but got an error:
runPrint: go build -v -x -tags noupgrade (...)
flag provided but not defined: -v -x
usage: go build [-o output] [build flags] [packages]
Run 'go help build' for details.
exit status 2
Ok, understood. But I’m clueless to what exactly I have to switch and if those LD_FLAGS, EXTRA_LDFLAGS, CGO_LDFLAGS get respected in the right place if I set them.
-v and -x should be separate variables in the array, also, it might be that -v needs to be passed to the C compiler.
Might be worth to check what gomobile is using.
gomobile build -x
Looks like we only really use cgo for darwin/solaris filewatcher implementation. In theory cross-compiling should be a lot easier without cgo?
Dns used to not work without cgo
So whats the goal here? Build with an ndk newer than r22?
I might have a look at if it’s clear what we want to achieve.
Yes, exactly. If you’ve got some time for this, I’d appreciate you looking into
Just vanilla bumping of numbers works fine for me:
I’ve merged your build script changes into my branch and it indeed worked. Strange, from code perspective I don’t see any significant changes, maybe it’s the NDK_VERSION value in build.gradle which causes some components to reconfigure things differently.
Thank you, we’re back into business with NDK r23 now !
P.S. I’ve also migrated to Android Studio Arctic Fox. Had the 2019.x version before on my computer.
Do you have any idea how to proceed with command line compilation?
Under Windows,
set "CC=<full-path-to-ndk>\toolchains\llvm\prebuilt\windows-x86_64\bin\armv7a-linux-androideabi16-clang.cmd"
set "CGO_ENABLED=1"
go run build.go -goos android -no-upgrade -goarch arm zip
works with no problems with the older NDKs, but with NDK r23 I still only get
runtime/cgo
# runtime/cgo
ld: error: cannot open output file $WORK\b083\_cgo_.o: Function not implemented
clang: error: linker command failed with exit code 1 (use -v to see invocation)
See the main branch of the fork (SyncthingNative_build.cmd) where I’ve adopted Audrius’ changes. Build works immediately using ndk r23.
ref: https://github.com/Catfriend1/syncthing-android/commit/28e84e929d37941b876b07d3310dfedf6f3dc9bd
You can’t set CC, you need to pass it as -cc, as it tries to use cgo to build build.go, which is not what you want.
I still have a problem when building under F-Droid vagrant and Debian amd64:
.../android-ndk-r23/toolchains/llvm/prebuilt/linux-x86_64/bin/clang: line 1: clang-12: command not found
apt-get install -y gcc gcc-arm-linux-gnueabi gcc-arm-linux-gnueabihf gcc-aarch64-linux-gnu
and then change the call in “build-syncthing.py” to “-cc /usr/bin/arm-linux-gnueabi-gcc”, I get a lot of include errors despite also setting the env var:
export SYSROOT=/root/work/syncthing-android-prereq/android-ndk-r23/toolchains/llvm/prebuilt/linux-x86_64/sysroot
I’ve read here it works on your docker image, what is the magic that CGO finds the correct gcc (or clang-12)?
Very strange, I’ve tried every mix of env vars - no luck. If I do:
echo "`dirname $0`/clang-12 $@" > /root/work/syncthing-android-prereq/android-ndk-r23/toolchains/llvm/prebuilt/linux-x86_64/bin/clang
the arm build starts to work magically. How can I do this “officially” without modding the Android NDK prebuilt files?
IHNI, but the Dockerfile is this:
and then we apparently build using a python script which I assume exists in your fork as well
which appears to do some gymnastics to set cc
Correct. Somehow a debian amd64 bullseye or F-Droid vagrant box isn’t able to search for the correct utility paths. I now did a hacky way and replaced the “clang” batch of the linux ndk r23 with
and everything works fine again.
I’m very sorry to bump this, but I’m still struggling to get the build to work. This time I’m not setting any CC variables myself. I’m just trying to follow the steps as described in detail in https://github.com/syncthing/syncthing-android/pull/1865/files, which basically are about setting the ANDROID_HOME
variable and then executing ./gradlew buildNative
However, the build still fails with a very similar error.
> Task :syncthing:checkPython
Using python 3.10.5 from C:\Users\User\AppData\Local\Programs\Python\Python310 (python)
> Task :syncthing:buildNative
[python] python -u ./build-syncthing.py
Building syncthing for arm
Notice: Next generation GUI will not be built; see --with-next-gen-gui.
runtime/cgo
net
golang.org/x/net/internal/socks
vendor/golang.org/x/net/http/httpproxy
log/syslog
net/textproto
github.com/lucas-clemente/quic-go/internal/utils
crypto/x509
golang.org/x/net/internal/socket
github.com/syncthing/syncthing/lib/protocol
github.com/rcrowley/go-metrics
github.com/jackpal/gateway
golang.org/x/net/proxy
github.com/jackpal/go-nat-pmp
vendor/golang.org/x/net/http/httpguts
github.com/ccding/go-stun/stun
golang.org/x/net/ipv4
golang.org/x/net/ipv6
crypto/tls
github.com/syncthing/syncthing/lib/beacon
github.com/syncthing/syncthing/lib/relay/protocol
net/http/httptrace
github.com/syncthing/syncthing/lib/tlsutil
github.com/marten-seemann/qtls-go1-19
net/http
github.com/lucas-clemente/quic-go/internal/qtls
github.com/lucas-clemente/quic-go/internal/qerr
github.com/lucas-clemente/quic-go/internal/wire
github.com/lucas-clemente/quic-go/logging
github.com/lucas-clemente/quic-go/internal/handshake
github.com/syncthing/syncthing/lib/dialer
github.com/go-ldap/ldap/v3
github.com/syncthing/syncthing/lib/osutil
github.com/syncthing/syncthing/lib/relay/client
github.com/syncthing/syncthing/lib/config
github.com/AudriusButkevicius/pfilter
github.com/syncthing/syncthing/lib/nat
github.com/syncthing/syncthing/lib/stun
github.com/syncthing/syncthing/lib/discover
github.com/syncthing/syncthing/cmd/syncthing/cli
github.com/syncthing/syncthing/lib/pmp
github.com/syncthing/syncthing/lib/upnp
github.com/syncthing/syncthing/lib/connections
github.com/syncthing/syncthing/lib/ur
github.com/syncthing/syncthing/lib/model
github.com/syncthing/syncthing/lib/api
# github.com/syncthing/syncthing/cmd/syncthing
C:\Program Files\Go\pkg\tool\windows_amd64\link.exe: running R:\commandlinetools-win-9123335_latest\ndk\23.0.7599858/toolchains/llvm/prebuilt//windows-x86_64/bin/armv7a-linux-androideabi16-clang failed: exit status 1
ld: error: cannot open output file $WORK\b001\exe\a.out: Function not implemented
exit status 2
exit status 1
Traceback (most recent call last):
File "R:\syncthing\syncthing-android\syncthing\build-syncthing.py", line 104, in <module>
subprocess.check_call(
File "C:\Users\User\AppData\Local\Programs\Python\Python310\lib\subprocess.py", line 369, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '['go', 'run', 'build.go', '-goos', 'android', '-goarch', 'arm', '-cc', 'R:\\commandlinetools-win-9123335_latest\\ndk\\23.0.7599858/toolchains/llvm/prebuilt//windows-x86_64/bin/armv7a-linux-androideabi16-clang', '-pkgdir', 'R:\\syncthing\\syncthing-android\\syncthing\\gobuild\\go-packages\\arm', '-no-upgrade', 'build']' returned non-zero exit status 1.
> Task :syncthing:buildNative FAILED
FAILURE: Build failed with an exception.
I’ve tried checking both the Docker build script and build-syncthing.py
, but I can’t see what is wrong with my build steps. Also, as far as I understand, when using ./gradlew buildNative
, the build-syncthing.py
is executed and CC is passed using -cc
automatically, yet the compilation still fails, so I’m really out of ideas what can be wrong here .
If anyone can point at any specific clues or has an idea what needs to be done to get this to work, I will be extremely grateful.
For the record, I’m trying to build under Windows 10 x64.
