Hi
I have a file that is about 512mb. The sync stops at 130mb (has 370mb to go) and does not go forward ;( Any recommendations?
Hi
Ok I deleted the local unfinished file and touched the file on the server and it synced fine. No idea why that was they case. Sorry for the noise.
You should check the logs on both sides next time.
