Just as the title says, my Android device thinks that the global state of a folder is far larger than its actual size.
Something does seem broken, judging by the video. I would try to remove the folder from Syncthing on Android and then try adding it again under the same location. For safety reasons, I would also initially set the folder to Receive Only and only change it later once everything has synced correctly.
