I’ve switched to an Android 14 device (Pixel 8 Pro).
So far Syncthing works well, except for one thing: when I edit an existing synced folder, it forces the Folder Type to “Send Only”. When I attempt to change it, I see a toast notification:
“Your Android version only grants Syncthing readonly access to the sele…”
However, two-way sync is working properly and files are getting created locally by Syncthing.
