Hello,
Is there a way to run a sort of “introducer” docker container that can run locally within the network that will allow 2 Android devices running 12 and 13 to “see” each other and synchronise?
I understand there is a limitation in Android that prevents Android devices from being able to discover each other and start synching?
I would personally consider running a private relay server only if I had a metered internet connection and/or the internet connection was really slow and/or I was synchronizing huge volumes of data.
The global relays are 1) always there for you, 2) enables good “out-of-the-box” experience without any special configuration.
I’m running one in a corporate environment to allow discovery between different network segments and WLAN where broadcast (for local discovery) is not available. Works like a charm, you just need to configure the additional discovery server address on each device.
