--------- beginning of main
07-02 10:31:25.833 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.836 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.837 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.840 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.843 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.845 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.848 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.850 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:25.852 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:27.510 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:27.510 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:27.511 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/version failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.842 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.842 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.843 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.844 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.845 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=d6603-photos failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.847 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.848 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.848 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.849 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.851 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.853 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.855 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.857 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:30.861 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:32.507 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:32.508 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/version failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:32.509 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.829 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.829 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.831 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=d6603-photos failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.831 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.832 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.833 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.834 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.834 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.835 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.837 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.839 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.841 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.843 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:35.844 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:37.507 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/version failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:37.509 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:37.510 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.874 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.874 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.876 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.880 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=d6603-photos failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.880 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.882 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.883 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.883 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.884 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.886 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.889 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.891 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.893 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:40.896 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:42.498 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:42.499 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:42.499 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/version failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.829 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.831 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.831 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.834 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=d6603-photos failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.835 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.836 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.836 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.839 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.840 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.842 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.844 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.847 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.850 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:45.852 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:47.506 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:47.509 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:47.509 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/version failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.411 I/Timeline(17125): Timeline: Activity_launch_request id:com.nutomic.syncthingandroid time:369493743
07-02 10:31:49.882 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.904 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.904 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=d6603-photos failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:49.905 I/Timeline(17125): Timeline: Activity_idle id: android.os.BinderProxy@fd36408 time:369494237
07-02 10:31:50.841 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.841 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.841 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.841 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.843 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.844 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.846 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.846 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.847 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=d6603-photos failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.849 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.851 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.854 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.855 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:50.857 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:52.416 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/version failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:52.416 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:52.416 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:54.298 I/Timeline(17125): Timeline: Activity_launch_request id:com.nutomic.syncthingandroid time:369498630
07-02 10:31:54.654 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/status failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:54.706 I/Timeline(17125): Timeline: Activity_idle id: android.os.BinderProxy@e5f93a0 time:369499038
07-02 10:31:55.829 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=1znd9-ojd6v failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.832 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=hlmkm-igt3g failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.832 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=6s7ry-09dz6 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.834 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=45k40-ez5y2 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.834 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=eppoc-cn8k4 failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.836 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=tkpqv-njz6t failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.837 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/system/connections failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
07-02 10:31:55.837 W/ApiRequest(17125): Request to https://127.0.0.1:8384/rest/db/status?folder=fgke7-xu6mh failed, java.net.ConnectException: failed to connect to /127.0.0.1 (port 8384) after 5000ms: isConnected failed: ECONNREFUSED (Connection refused)
