The current implementation of strelaysrv permits the flow of traffic between two clients using a single Relay server. This is usually the most efficient transport method:
client <---> relay <---> client
In some scenarios, allowing blocks within a cluster to transverse multiple Relay servers may be beneficial:
client <---> relay <---> relay <---> client
DigitalOcean operates a dedicated backbone network, interconnecting their datacenters using dark fiber and asynchronous paths. This means a DO server in Amsterdam can ping another instance in New York City faster than it could over the public internet. Allowing multi-relay routing could take advantage of peering situations like this and increase overall sync performance.
