Here’s an update on what’s going on with the “persistent index database” feature. I’ve been trying to integrate with the various embedded data stores I’ve found, and most don’t work for our purposes. Here’s a list/log of the packages I’ve tried and how it goes.
Wont Work
SQLite
Full featured, stable, insanely awesome test suite. Written in C, doesn’t cross compile nicely with the Go toolchain. Setting up build environments for all my target platforms is more pain than I need.
QL
Native Go SQL-like data store. Lacking a few relevant SQL features mainly around indexes, has some issues (a weirdly hidden WAL file and no guarantee that a successful transaction commit will actually make it to disk).
KV
Key-value store that underlies QL, so shares the limitations apart from not being SQL-like.
jmhodges/levigo
Uses the leveldb shared library, so no cross compilation and no single binary deployment.
leveldb-go
Hasn’t implemented enumeration which I need from a kv store.
Tiedot
Native Go key-value store, requires roundtripping data through JSON. Clobbers large integers, fairly inefficient.
diskv
Native Go key-value store, stores each item as a separate file on disk…
Might Work
These are the ones I’m working on integrating with at the moment.
Bolt
Native Go key-value store. Has some bugs and issues that are being sorted out, if it works out it looks nice.
syndtr/leveldb
Yet another leveldb implementation, this one in pure Go and looks promising. Still early in the integration work.
