Hi, I don’t know this is intended behaviour : I’m synching a ~small~ part of a huge remote dir with:
!2015/201505 A
2015/*
!2015
then while syncthing I add another so that:
!2015/201505 A
2015/*
!2015
!2014/201406 B
2014/*
!2014
I save the change both on stignore then folder dialog but after waiting enough time (folder set at random and several files from 2015 were synch’d) 2014 won’t start. Thinking I forgot to save my changes a look at stignore dialog doesn’t show them. Retype and carefully save again => same issue. Then I check the .stignore file and my changes are there OK. I was not prompted to restart ST. I clicked “Rescan all”, still no 2014 sync. Restarting started 2014 folder sync.
I wander if 2014 would have started when 2015 was finished ?
