Hi
I read old style long options (e.g. -home
) is no longer supported. Is it true in Windows too ?
Thank you
Hi
Thank you
As I understand it, that is correct for v2. Deprecated but still works for v1.x.
Command line options are interpreted the same on all platforms. Long form double dashes have always worked in Syncthing, just it wasn’t always what was documented and printed in the help. (This is an idiosyncrasy of the Go standard flags
package.)
My question was because I wander if I have to instruct my friends/family still in Windows to pre-fix their -no-console
option in their shell:startup
shortcut.
Yes, I would recommend that you do that.
Thank you
