Aborted scan of path ... file does not exist
I get flags in the GUI:
2025-11-14 06:21:51: Aborted scan of path ‘z840-1.mail/.thunderbird/3xqyqis0.default/Mail/mail.sdi-baja.com/friends.sbd/.Ehlerts y Petersons.y66A3X’ due to an unexpected error: file does not exist
2025-11-14 06:23:41: Aborted scan of path ‘archive/.thunderbird/3xqyqis0.default/Mail/mail.sdi-baja.com/friends.sbd/.Ehlerts y Petersons.B8Pl9X’ due to an unexpected error: file does not exist
I click OK. when I update the .thunderbird folder it returns … Not always the same “non-existing” files.
Happens on a couple of the nodes too
oops: running Debian Trixie, Mate desktop. syncthing installed from the Debian repositories
No data loss that I detect, just Annoying
nobody knows and nobody care… cool, I can go with that
Is Thunderbird running when this happens?
yes
That’s why. Thunderbird is deleting files after they’ve been scanned but before they’ve been synced.
My recommendation is to consider pausing the Folder that Thunderbird is using, while you’re using it. You could script it to happen automatically.
Another valid option is to ignore the error messages.
It’s a bug, should be filed on GitHub.
pardon me. No. Thunderbird is closed
My personal Rule #1 for Syncthing Club is to not disagree with @calmh :grin:.
Indeed, I recommend that you file a bug for this one.
fine, good idea. where in that GitHub to be found?
found and filed
