I started with 5 synced devices, and I just added a NAS as the 6th, but for some reason when I setup the final sync, one pair refuses to communicate. I re-setup it again and its the same result. There is data to be synced between them, but it gives 6 errors on both sides. What should I do?
quic://###############
no recent network activity (09:30:38)
network is unreachable (09:30:33)
tcp://################
i/o timeout (09:30:08)
network is unreachable (09:29:58)
Hard to tell with that little information. The two devices seem to have problems to discover each other. This is most likely caused by both of them being unable to gather their own IPs.
All synced devises are just running on Windows 10, except the new Synology NAS that I just added. The missing connect is between the NAS and one of the Windows 10 machine. Everything else communicates fine.
I apologize if i’m missing anything in response, I’m learning all of this as I go.
That one was set to public, so I switched it to private, but its still not connecting. Just getting time-outs then unreachable in the errors.
For context aswell, All the windows machines are identical hardware, only they exists in different psychical locations and on different networks. I’m remoting in to both so I know for sure they are both online.
@bt90 How do I do that without doxing myself or my coworkers? Do i just pull the ip address/port from the browser URL when accessing the Syncthing UI?
Sorry if its a dummy question, like I said, I’m learning as I go here.
I missed the important bit. Which nodes are refusing to connect? There’s a chance that both of them are unreachable from outside without a relay because of their NAT type or the provider only using CGNAT.
@bt90 Its the Nodes labeled “Peter” and “WPI_NAS”. “Peter” is the one that was set to a public network, and I switched it over to private. All the nodes talk to each other fine, I have one sync that is from my node “Joe” shared with “Peter” and “WPI NAS” and both are receiving it, they just dont send between each other.
Strange, it says 4/5 now… looks like they’re all 4/5 with a “Failure to connect to IPv6 servers is expected if there is no IPv6 connectivity.” message
I’m not sure if I know how to answer that. I downloaded the app from the Synology Community app/package center. When I launch it opens its own browser tab.
