rafik
(Rafal)
April 10, 2021, 10:36pm
#1
Just detected that Syncthing doesn’t work on my Odroid-C2 with attached USB drive.
Page https://192.168.1.118:8384 simply doesn’t open:
Unable to connect
Firefox can’t establish a connection to the server at 192.168.1.118:8384.
Started troubleshooting and conclusion is that Syncthing 1.14.0 automatically updated to 1.15.1 causing this issue.
Restored CoreELEC from backup (contain Syncthing 1.14.0)
Unplugged LAN cable
Disabled Syncthing add-on in Kodi (device accessible via CEC)
Plugged back LAN cable
set 0 in config.xml:
< autoUpgradeIntervalH >0< /autoUpgradeIntervalH >
Enabled Syncthing add-on in Kodi
Syncthing 1.14.0 works properly.
bt90
(Bt90)
April 11, 2021, 4:33am
#2
Hard to tell without logs. Could you try v1.15.1 and upload the log generated by syncthing?
Andy
(Andreas Kaelber)
April 11, 2021, 5:50am
#3
Odroid C2 only is the hardware. Which OS you are using?
rafik
(Rafal)
April 11, 2021, 7:16am
#4
Syncthing web page says:
in ssh:
Logs files I will be able to provide later on…
rafik
(Rafal)
April 11, 2021, 9:51am
#5
Nothing is recorded in the log file:
[4PWWL] 2021/04/11 11:33:08 github.com/syncthing/syncthing/lib/connections/quic_listen.go:55: INFO: quic://0.0.0.0:22000 detected NAT type: Port restricted NAT
[4PWWL] 2021/04/11 11:33:08 github.com/syncthing/syncthing/lib/connections/quic_listen.go:74: INFO: quic://0.0.0.0:22000 resolved external address quic://185.244.214.233:22000 (via stun.syncthing.net:3478)
[4PWWL] 2021/04/11 11:38:17 github.com/syncthing/syncthing/lib/connections/quic_listen.go:123: INFO: QUIC listener ([::]:22000) shutting down
[4PWWL] 2021/04/11 11:38:17 github.com/syncthing/syncthing/lib/model/model.go:1741: INFO: Connection to XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX-XXXXXXX at 192.168.1.118:22000-192.168.1.126:22000/tcp-client/TLS1.3-TLS_CHACHA20_POLY1305_SHA256 closed: Syncthing is being stopped
[4PWWL] 2021/04/11 11:38:17 github.com/syncthing/syncthing/lib/model/model.go:1741: INFO: Connection to YYYYYYY-YYYYYYY-YYYYYYY-YYYYYYY-YYYYYYY-YYYYYYY-YYYYYYY-YYYYYYY at 192.168.1.118:22000-192.168.1.109:22000/tcp-client/TLS1.3-TLS_AES_128_GCM_SHA256 closed: Syncthing is being stopped
[4PWWL] 2021/04/11 11:38:17 github.com/syncthing/syncthing/lib/connections/relay_listen.go:122: INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[4PWWL] 2021/04/11 11:38:17 github.com/syncthing/syncthing/lib/relay/client/static.go:114: INFO: Disconnected from relay relay://51.83.132.1:443
[4PWWL] 2021/04/11 11:38:18 github.com/syncthing/syncthing/lib/connections/tcp_listen.go:100: INFO: TCP listener ([::]:22000) shutting down
[4PWWL] 2021/04/11 11:38:18 github.com/syncthing/syncthing/lib/syncthing/syncthing.go:346: INFO: Exiting
Once I have pressed the button “Upgrade To v1.15.1” it is only showing this:
When Odroid-C2 is restarted (manualy) no entries in the log file, web page looks like:
Andy
(Andreas Kaelber)
April 11, 2021, 10:58am
#6
Maybe is better to install the right version of Syncthing 64-bit first.
rafik
(Rafal)
April 11, 2021, 11:02am
#7
Version what is installed is the official one available in CoreELEC repository.
I will stay on 1.14.0 as apparently the new one 1.15.1 doesn’t work.
Andy
(Andreas Kaelber)
April 11, 2021, 11:08am
#8
rafik:
on 1.14.0
Is 32-bit and work … If you try v1.15.1 as 64-bit as installation on manual way?
imsodin
(Simon)
April 11, 2021, 11:28am
#9
If it comes from a third party repository, please indicate that when asking for help - that’s very important information.
Given you are using the CoreELEC repository, i.e. their builds, the update is likely unintended. Probably changes something about their build process and somehow messed up disabling auto-upgrades. In any case, that’s a question for the support venue of CoreELEC.
As to the logs you posted: They only show how syncthing stops, nothing more. Logs of the subsequent start attempt would be interesting. If there aren’t any, you need system logs of whatever manages running Syncthing. That’s a gain a question for CoreELEC.
rafik
(Rafal)
April 11, 2021, 11:34am
#10
Yes, I have realized that as well - it’s all the matter of CoreELEC repository.
For the old version 9.2.7 apparently repository contain old Syncthing version and when autoupdate is performed through Syncthing itself it is causing this critical issue.
For the new version 19.1 Matrix there is available Syncthing 1.15.1 in CoreELEC respository.
I have already asked the question if we can expect Syncthing update in CoreELEC 9.2.7.
Sorry for my alert
system
(system)
closed
May 11, 2021, 11:34am
#11
