Anyways, I am suspect this is not the case as devices don’t advertise their names (atleast in that one screenshot)
Indeed, there is never a name associated with these (seemingly) random devices.
the logs around the time when these devices connected would help understand this better.
So, I ran syncthing -paths
and got this:
Log file:
/Users/$USER/Library/Application Support/Syncthing/syncthing.log
When I try to access that location, it says it doesn’t exist however, and in-fact a search of my whole system returns nothing:
find ~/ -name "*syncthing.log" -type f 2> /dev/null
and
find / -name "*syncthing.log" -type f 2> /dev/null
exit with no output.
However, I was running syncthing from a terminal window I still had open, so I went in search of anything related to this mystery device. The only line referencing the Device ID is:
[N4JA2] 15:42:28 INFO: Connection from 7RHIEFB-6XVEVP3-T6JDQWZ-3TVFNTE-PTXKVOU-EHJJ63Y-7JXTVM5-QKBLAQ7 at 192.168.1.4:22020 (kcp-server) rejected: unknown device
Here are the surrounding lines from the log:
[N4JA2] 15:40:51 INFO: Failed to exchange Hello messages with LR76FOF-GR3QF4G-OUZUNYY-LWE3QSP-7HDM7IK-JWWSKF7-AOBHKSG-352LBAK (192.168.1.2:22000): read tcp 192.168.1.11:52124->192.168.1.2:22000: i/o timeout
[N4JA2] 15:41:50 INFO: Connection to AJ2GQWR-KDDYVYC-IQ74TAY-LTDYMGP-CVV43EJ-ZDIYPD2-T6ZSPYI-N76JYA2 closed: writing message: write tcp 192.168.1.11:22000->192.168.1.13:59484: write: can't assign requested address
[N4JA2] 15:41:58 INFO: Connection to XVD4YVE-ZZCYN54-FVJYIRP-V4L7T27-HXOONLY-IDQNE4A-LFSNEMM-QEPC7QD closed: writing message: write tcp 192.168.1.11:52002->192.168.1.8:22000: write: can't assign requested address
[N4JA2] 15:48:48 INFO: Couldn't fetch release information: Get https://upgrades.syncthing.net/meta.json: dial tcp: lookup upgrades.syncthing.net: no such host
[N4JA2] 15:48:50 INFO: Exiting backoff state.
[N4JA2] 15:48:50 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[N4JA2] 15:48:51 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) shutting down
[N4JA2] 15:48:51 INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.000000 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
[N4JA2] 15:48:51 INFO: Relay listener (dynamic+https://relays.syncthing.net/endpoint) starting
[N4JA2] 15:48:51 INFO: c.S.listenerSupervisor: Failed service 'dynamic+https://relays.syncthing.net/endpoint' (1.999965 failures of 2.000000), restarting: true, error: "{dynamic+https://relays.syncthing.net/endpoint dynamic+https://relays.syncthing.net/endpoint} returned unexpectedly", stacktrace: [unknown stack trace]
LR76FOF
is a device running on the same network, but is using a VPN (so perhaps it’s connecting over the VPN?)
AJ2GQWR
is a desktop wired into the same network the laptop you are reading the logs from is connected to (but over wifi.)
XVD4YVE
is another desktop also wired into the same network. Note both desktops so far are connected through ethernet extenders that plug into wall sockets.
7RHIEFB
is the mystery device asking to be added from the wi-fi extender’s IP address.
