I am using Endeavouros Linux. Setting Sync folder on this Linux for the first time.
Sync with my handphone Android J6+ which has already have syncthing installed and running for Manjaro linux (i have since switched from Manjaro to Endea linux).
May i know what kept it from me “click” save button ?
What version are you running? Oh, it says 1.9.0. Odd.
The problem is that the Cleanup Interval field on the File Versioning tab is empty. Set it to 3600. But I didn’t think we had this problem in any released version.
What does cleanup Interval means ? to periodically clean up older versioning data of the .stversions directory ?
Does the value of 3600 seconds in Cleanup Interval means it do a cleaning of versioning data every hour ?!
If it keep removing the versioning data, then when got Data conflict … how to recover if it is cleaned ?
Well, this is the default behavior of the official 1.9.0 APT/GitHub release though.
To reproduce, simply add a new folder through the GUI and select for example ‘Staggered File Versioning’ (Trash Can is also affected). Both the Versions Path and the Cleanup Interval fields will be blank, while Maximum Age has a preselected value of 365.
The versioning folder is checked from time to time, to see if there are versions that should be removed. The Cleanup Interval controls how often this check is performed. The files are then removed according to the schedule.
The setting is mainly meant to give the user control on how often a spinning disk should be polled due to versioning.
It means every hour it will see if there are files to delete from the .stversions directory (if they are old enough, following your maximum age setting).
