Could you tell me what’s the usage of relay?
what i want to do is using syncthing to setup a homelab environment for all my devices. but after setup, the syncthing has the connect to outside( Joined relay relay://103.241.61.30:22067
Is it possible to disable such feature?
version: syncthing v0.14.26 “Dysprosium Dragonfly” (go1.8 darwin-amd64) jenkins@build.syncthing.net 2017-03-23 11:04:35 UTC
