chrisisbd
(Chris Green)
June 4, 2016, 12:08pm
1
I knew I was going to ask something else about logging! Never mind a separate thread isn’t a bad idea.
As per the subject, what do ‘long filename’ and ‘short filename’ mean in the command line -logflags parameter? What file are we talking about here?
canton7
(Antony Male)
June 4, 2016, 12:47pm
2
Search for Llongfile
and Lshortfile
here .
chrisisbd
(Chris Green)
June 4, 2016, 2:00pm
3
I’m none the wiser!
It doesn’t tell me what file it is talking about. Is it the file causing the error (but not all errors are caused by a specific file), the code’s source file, or what?
When it logs the location of where the log line came from, this flag decides if the full path is used, or only the filename.
This has nothing todo with functionallity, just general logging for debugging.
calmh
(Jakob Borg)
June 4, 2016, 4:14pm
5
Try it and see, if nothing else.
system
(system)
Closed
July 4, 2016, 4:22pm
6
