jose-pr
(Jose A)
1
I want to sync a lot of media files from one site to another.
Site 1 (Source):
- 1Gpbps up/down
- ~9TB in a 50TB RAID10
- Mostly larges files > 5GB
- PFSense firewall
- no relay being used.
Site 2 (Dest):
- 250/25 Mbps
- 10TB RAID10
- PFSense firewall
I did some speed test and i get around >800mbps on the source (up and down) and >200mbps on the destination down.
But syncthing only looks to be using around 30-50mbps.
What can i be missing?
CPU usage doesnt seem to be high in either end for the firewall/router or syncthing host.
bt90
(Bt90)
2
I’d also check the speed from source to dest uising iperf to make sure that it’s not just limited by your providers peering.
A typical bottleneck is usually syncthings database. Is it located on the same RAID? It should be on a separate disk and preferable on a SSD.
It can also be bottlenecked by the CPU hashing speed. The hash rate is printed on startup.
system
(system)
Closed
4
