Were is a spurious node RJR2G2A coming from? In shows on none of my GUI panels and doesn’t match the list of devices processed at boot up time. I noticed this error because the warning pops up on the syncthing GUI for me to read and click through.
The log below is extracted from 10.0.0.123 (node 3T7HJJ7) as it boots up syncthing. I stripped all but the first 6 characters of node ids for privacy. And I replaced a real remote IP with “a.b.c.d” for privacy. Notice 6 nodes are processed at boot up time and none of them are RJR2G2A. This matches the booting computer and the 5 nodes defined on its syncthing GUI. Then the message at 48.671 tries to connect to RJR2G2A. Where is this node ID coming from? It is not associated with any of my ID numbers on the network, and does not show in the logs of any other nodes on the network.
As an aside, I’m unsure what “did not negotiate bep” means, but that is strange anyhow, because 10.0.0.123 is the computer booting up so why is it calling itself a peer and trying to negotiate something with itself?
[3T7HJ] 2019/08/15 08:26:32.370029 INFO: Device BXBD6EM- is "Offsite Repository" at [tcp://a.b.c.d:22000]
[3T7HJ] 2019/08/15 08:26:32.370198 INFO: Device C2PVFR6- is "Dell-E6440" at [dynamic]
[3T7HJ] 2019/08/15 08:26:32.370300 INFO: Device OCLV7CX- is "bmmbp" at [dynamic]
[3T7HJ] 2019/08/15 08:26:32.370427 INFO: Device O2YGBV4- is "inspiron-linux" at [dynamic]
[3T7HJ] 2019/08/15 08:26:32.370511 INFO: Device 2YNUA3L- is "Elite-Win10" at [dynamic]
[3T7HJ] 2019/08/15 08:26:32.370598 INFO: Device 3T7HJJ7- is "raspberrypi" at [dynamic]
[3T7HJ] 2019/08/15 08:26:32.386921 INFO: GUI and API listening on [::]:8384
[3T7HJ] 2019/08/15 08:26:32.387041 INFO: Access the GUI via the following URL: http://127.0.0.1:8384/
[3T7HJ] 2019/08/15 08:26:33.673739 INFO: Peer at 10.0.0.123:45372-a.b.c.d:22000/tcp-client did not negotiate bep/1.0
[3T7HJ] 2019/08/15 08:26:48.671929 WARNING: Connecting to RJR2G2A- (a.b.c.d:22000): the remote device speaks an unknown (newer?) version of the protocol
[3T7HJ] 2019/08/15 08:26:48.673648 INFO: Established secure connection to C2PVFR6- at 10.0.0.123:48014-10.0.0.115:22000/tcp-client (TLS_ECDHE_ECDSA_WITH_AES_256_GCM_SHA384)
[3T7HJ] 2019/08/15 08:26:48.679449 INFO: Established secure connection to BXBD6EM- at 10.0.0.123:22150-a.b.c.d:43832/tcp-server (TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305)
[3T7HJ] 2019/08/15 08:26:49.455972 INFO: Established secure connection to OCLV7CX- at 10.0.0.123:54666-10.0.0.107:22152/tcp-client (TLS_ECDHE_ECDSA_WITH_CHACHA20_POLY1305)
