was running fine...until this happened
16:34:29 INFO: syncthing v1.2.0 “Fermium Flea” (go1.12.6 windows-amd64) teamcity@build.syncthing.net 2019-06-28 06:03:29 UTC 16:34:29 INFO: My ID: ---- 16:34:30 INFO: Single thread SHA256 performance is 420 MB/s using minio/sha256-simd (359 MB/s using crypto/sha256). 16:34:30 WARNING: Failed to initialize config: Config file version (31) is newer than supported version (29). If this is expected, use -allow-newer-config to override. 16:34:30 INFO: syncthing v1.2.0 “Fermium Flea” (go1.12.6 windows-amd64) teamcity@build.syncthing.net 2019-06-28 06:03:29 UTC
You somehow managed to downgrade syncthing to an older version.
what do i do now?
please help
Install a newer/newest version
