Just updated to version 0.10.2. Everything works fine. Initial scan and sync ran fast. Just one little annoyance. A warning. Here are the logs:
May 04 19:03:50 burner-tux syncthing[293]: [6UVMX] INFO: Adding device RVI6REN-<hash> to share "droid-camera" (vouched for by introducer 2E3ISIP-<hash>)
May 04 19:03:50 burner-tux syncthing[293]: [6UVMX] INFO: Adding device RVI6REN-<hash> to share "droid-music" (vouched for by introducer 2E3ISIP-<hash>)
May 04 19:03:50 burner-tux syncthing[293]: [6UVMX] INFO: Adding device RVI6REN-<hash> to share "droid-pictures" (vouched for by introducer 2E3ISIP-<hash>)
May 04 19:04:02 burner-tux syncthing[293]: [6UVMX] INFO: Completed initial scan (rw) of folder droid-camera
May 04 19:04:22 burner-tux syncthing[293]: [6UVMX] INFO: Completed initial scan (rw) of folder OC_neroburner
May 04 19:04:58 burner-tux syncthing[293]: [6UVMX] WARNING: Broadcast: interface addresses: netlink rib: invalid argument
May 04 19:05:05 burner-tux syncthing[293]: [6UVMX] INFO: Completed initial scan (rw) of folder droid-pictures
May 04 19:05:19 burner-tux syncthing[293]: [6UVMX] INFO: Completed initial scan (rw) of folder direct_share
May 04 19:05:35 burner-tux syncthing[293]: [6UVMX] INFO: Completed initial scan (rw) of folder OC_Shared
May 04 19:05:46 burner-tux syncthing[293]: [6UVMX] INFO: Completed initial scan (rw) of folder droid-music
and the same warning popping up on the web-end
19:04:58: Broadcast: interface addresses: netlink rib: invalid argument
It works great, it is just a little annoying and I would like to know what is causing it.
Cheers Nero
