@imsodin Just sent you that the output by gmail.
@rustycanb May I share information (no IPs, no full device IDs) from your emails? That stuff is not sensitive and unless itās obvious what happens and how to fix it (havenāt yet had a chance to look) I will need to run theories by other people - and actual log/file-info examples make that a lot easier than trying to describe the situation abstractly.
@imsodin Sure, no problem. Thanks again for persisting to try and resolve this issue.
BTW, I tried a simple connection between two laptops, A and B, one receive encrypted folder on B with a few files. Touching a file on A caused the Unexpected Items to appear on B only after a rescan. Both laptops on rc.1. Downgrade to 1.23.2 on B and the issue is not reproducible.
What OS and filesystem do you have on both sides? In principle that shouldnāt matter - I am grasping at straws given you can even reproduce in a test setup and I canāt, which makes no sense to me.
Both laptops are on Xubuntu 22.10 with the OS and data on separate partitions, all are XFS. SSD in one, M.2 in the other. Syncthing db and config are on data partition symlinked from ~/home.
Both Pis have Debian Bulleye ext4 OS partitions with data of separate XFS partitions. High quality newish SD cards in both.
@rustycanb In case you havenāt seen the other topic: Luckily I found the reason why I couldnāt reproduce thanks to help from @er-pa, and a fix is pending. Well most likely a fix, itās never 100% certain that it is the same thing you see.
@imsodin @er-pa Great work! Thanks for tracking this down. Iāll wait for the new RC and test again to confirm with four devices upgraded.
With rc.2 installed, all devices are working as expected. Thanks again @imsodin
Great work on this superb software.
