All my remote Syncthing instances have not auto restarted after the rc2 upgrade.
What do you mean? Can you describe the problem? What happened what you expect to happen?
So in the past, when any type of update has been applied (RC or full version), Syncthing will restart. However in all my instances Syncthing was not running / closed completely so I had to go to each device and open Syncthing.
Just found this in synctrazors logs (may or may not be relevant)…
[RTF25] 19:57:31 INFO: Automatic upgrade (current “v1.2.1-rc.1” < latest “v1.2.1-rc.2”) [RTF25] 19:57:33 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:57:34 WARNING: Automatically upgraded to version “v1.2.1-rc.2”. Restarting in 1 minute. [RTF25] 19:57:50 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:11 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:34 INFO: QUIC listener ([::]:22000) shutting down [RTF25] 19:58:34 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:34 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:34 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:34 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:34 INFO: Connection to xxxxxxxxxxxx closed: Syncthing is being stopped [RTF25] 19:58:35 INFO: TCP listener ([::]:22000) shutting down [RTF25] 19:58:44 INFO: connections.Service: Service &util.service{serve:(func(chan struct {}) error)(0x8c82a0), stop:(chan struct {})(0xc0002d3080), stopped:(chan struct {})(0xc0002d30e0), err:error(nil), mut:(*sync.Mutex)(0xc000249ff8)} failed to terminate in a timely manner 2019/07/17 19:58:44 Supervisor discover.cachingMux: discover.cachingMux: Service IPv6 local failed to terminate in a timely manner 2019/07/17 19:58:44 Supervisor local: local: Service multicastBeacon failed to terminate in a timely manner [RTF25] 19:58:44 INFO: Exiting
I am not sure its relevant, but you should open a github issue never the less.
Is a lib/syncthing issue, PR ready for review.
Does this cover it not starting back up?
Yes, it’s entirely about that.
