I’m getting the following error when building syncthing v0.9.4:
Relying on packaging to define the extension of the main artifact has been deprecated and is scheduled to be removed in Gradle 2.0
:buildNative
rm: das Entfernen von »bin/“ ist nicht möglich: Datei oder Verzeichnis nicht gefunden
? github.com/syncthing/syncthing/auto [no test files]
# github.com/syndtr/goleveldb/leveldb/table
Godeps/_workspace/src/github.com/syndtr/goleveldb/leveldb/table/reader.go:533: undefined: sync.Pool
ok github.com/syncthing/syncthing/beacon 0.043s
? github.com/syncthing/syncthing/cmd/stevents [no test files]
? github.com/syncthing/syncthing/cmd/stindex [no test files]
? github.com/syncthing/syncthing/cmd/syncthing [no test files]
ok github.com/syncthing/syncthing/config 0.055s
? github.com/syncthing/syncthing/discover [no test files]
ok github.com/syncthing/syncthing/events 2.321s
FAIL github.com/syncthing/syncthing/files [build failed]
ok github.com/syncthing/syncthing/lamport 0.003s
ok github.com/syncthing/syncthing/logger 0.012s
ok github.com/syncthing/syncthing/luhn 0.032s
FAIL github.com/syncthing/syncthing/model [build failed]
? github.com/syncthing/syncthing/osutil [no test files]
ok github.com/syncthing/syncthing/protocol 4.427s
ok github.com/syncthing/syncthing/scanner 0.042s
ok github.com/syncthing/syncthing/upgrade 0.010s
ok github.com/syncthing/syncthing/upnp 0.042s
? github.com/syncthing/syncthing/versioner [no test files]
godep: go exit status 2
:buildNative FAILED
:copyNative UP-TO-DATE
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':buildNative'.
> Process 'command './build-native.sh'' finished with non-zero exit value 1
* Try:
Run with --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
BUILD FAILED
Total time: 22.095 secs
Go version is “go1.2.1 linux/amd64”.
I can build v0.9.2 without problems.
