Hello, if I were to install the Beta, would it auto update to the final release? Also, are there any known issues with the Beta that may cause incompatibilities with the final release? Thanks!
Yes. No. Please try it.
Okay, I guess I will!
I am using it and it solved a ton of problems for me, caused by long file paths. I didn’t notice anything broken for now.
