Use sync as a transmission tool instead of synchronization
Synchronization means that it make two same mirror between two device. Install sync both on vps-a and vps-b,and make them share the files in directory. When you add or delete files in vps-a ,the files in vps-b will add or delete too. vps-a is a mirror of vps-b, vice versa ,vps-b is a mirror of vps-a.
Now i have a special requirement: Use sync as a transmission tool instead of synchronization. 1.Make vps-b the mirror of vps-a Take same action in vps-b when files added or deleted in vps-a. 2.vps-a is not the mirror of vps-a. No files added or deleted in vps-a when files added or deleted in vps-b.
How to accomplish the mission successfully with sync?
If I understand you correctly, set vps-a as “send only”.
Why don’t you use use a different tool?
