After upgrading all 3 of my devices (2x Windows, 1x Linux) to 0.13, I’m unable to connect through my router using UPnP. Previously, on 0.12, I had no problems. Specifying port forward rules allows them to pass through (port forward TCP port 22000).
UPnP does not require rules, so you must be confusing something. Also, make sure all devices are on 0.13.
It seems like I was not clear.
UPnP fails. However, I can get around this issue by using port forwarding rules whereas before, I did not have any port forward rules.
All devices are on 0.13.
Does it provide an error message?
Can run with STTRACE=nat,upnp environment variable, and provide the logs of the failure?
It does not provide an error - it will connect through a relay if I let it. If I disable relays, it just doesn’t connect.
Attached are logs from the two windows devices. The linux device has the port forward rule so it is able to make a direct connection, but without the port forward rule, it would also be on a relay or not connected.
I tried setting the environmental variable, but I am not sure they worked with Synctrayzor.
HOME (behind router and UPnP): http://pastebin.com/QqcnCMxv
Can you get the logs with the debug flags?
Also add pmp,discovery
to the mix: STTRACE=upnp,nat,pmp,discovery
I set the variable in a command window like this and then restarted Synctrayzor. Is there some other way?
set STTRACE=nat,upnp
There are probably debug options in synctrayzor somewhere.
Found them, letting the logs populate after restarting syncthing, and will send them shortly.
WORK, not behind router:
[XVEBW] 2016/05/26 16:02:18.581892 main.go:561: INFO: syncthing v0.13.4 "Copper Cockroach" (go1.6.2 windows-amd64) WIN-P6RP886TVDJ\Administrator@WIN-P6RP886TVDJ 2016-05-26 09:16:08 UTC
[XVEBW] 2016/05/26 16:02:18.581892 main.go:562: INFO: My ID: XVEBWC6
[XVEBW] 2016/05/26 16:02:18.884910 main.go:853: INFO: Single thread hash performance is ~190 MB/s
[XVEBW] 2016/05/26 16:02:22.897139 model.go:209: INFO: Ready to synchronize eptesicus_forest_collab (readwrite)
[XVEBW] 2016/05/26 16:02:25.901311 model.go:209: INFO: Ready to synchronize nhwhg_collab (readwrite)
[XVEBW] 2016/05/26 16:02:28.146440 model.go:209: INFO: Ready to synchronize small_space_beampattern (readwrite)
[XVEBW] 2016/05/26 16:02:28.168441 model.go:209: INFO: Ready to synchronize ISOs (readwrite)
[XVEBW] 2016/05/26 16:02:28.169441 main.go:705: INFO: Using discovery server https://discovery-v4-1.syncthing.net/v2/?id=SR7AARM
[XVEBW] 2016/05/26 16:02:28.169441 main.go:705: INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY
[XVEBW] 2016/05/26 16:02:28.169441 main.go:705: INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3
[XVEBW] 2016/05/26 16:02:28.169441 main.go:705: INFO: Using discovery server https://discovery-v6-1.syncthing.net/v2/?id=SR7AARM
[XVEBW] 2016/05/26 16:02:28.169441 main.go:705: INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY
[XVEBW] 2016/05/26 16:02:28.169441 main.go:705: INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3
[XVEBW] 2016/05/26 16:02:28.184442 main.go:750: INFO: Device G7PJ4UV is "killerdeathman" at [dynamic]
[XVEBW] 2016/05/26 16:02:28.184442 main.go:750: INFO: Device XVEBWC6 is "fuscination" at [dynamic]
[XVEBW] 2016/05/26 16:02:28.184442 main.go:750: INFO: Device 44HMFSN is "pine64" at [dynamic]
[XVEBW] 2016/05/26 16:02:28.188442 tcp_listen.go:69: INFO: TCP listener ([::]:22000) starting
[XVEBW] 2016/05/26 16:02:28.204443 usage_report.go:264: INFO: Starting usage reporting
[XVEBW] 2016/05/26 16:02:28.207443 rwfolder.go:307: INFO: Completed initial scan (rw) of folder ISOs
[XVEBW] 2016/05/26 16:02:28.209443 gui.go:347: INFO: GUI and API listening on 127.0.0.1:8384
[XVEBW] 2016/05/26 16:02:28.209443 gui.go:348: INFO: Access the GUI via the following URL: http://localhost:8384/
[XVEBW] 2016/05/26 16:02:28.220444 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Local Area Connection
[XVEBW] 2016/05/26 16:02:28.223444 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Local Area Connection
[XVEBW] 2016/05/26 16:02:28.223444 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Local Area Connection
[XVEBW] 2016/05/26 16:02:28.230444 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Local Area Connection
[XVEBW] 2016/05/26 16:02:28.231444 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1
[XVEBW] 2016/05/26 16:02:28.235445 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Local Area Connection
[XVEBW] 2016/05/26 16:02:28.235445 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Local Area Connection
[XVEBW] 2016/05/26 16:02:28.235445 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1
[XVEBW] 2016/05/26 16:02:28.236445 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1
[XVEBW] 2016/05/26 16:02:28.236445 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1
[XVEBW] 2016/05/26 16:02:28.240445 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1
[XVEBW] 2016/05/26 16:02:28.240445 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1
[XVEBW] 2016/05/26 16:02:31.229616 rwfolder.go:307: INFO: Completed initial scan (rw) of folder small_space_beampattern
[XVEBW] 2016/05/26 16:02:31.515632 service.go:229: INFO: Established secure connection to G7PJ4UV at 10.160.95.179:55580-199.15.254.138:443 (Relay (Client))
[XVEBW] 2016/05/26 16:02:31.515632 model.go:1044: INFO: Device G7PJ4UV client is "syncthing v0.13.4" named "killerdeathman"
[XVEBW] 2016/05/26 16:02:32.590694 service.go:229: INFO: Established secure connection to 44HMFSN at 10.160.95.179:55590-23.92.71.120:443 (Relay (Client))
[XVEBW] 2016/05/26 16:02:32.590694 model.go:1044: INFO: Device 44HMFSN client is "syncthing v0.13.4" named "pine64"
[XVEBW] 2016/05/26 16:02:32.627696 rwfolder.go:307: INFO: Completed initial scan (rw) of folder nhwhg_collab
[XVEBW] 2016/05/26 16:02:34.221787 rwfolder.go:307: INFO: Completed initial scan (rw) of folder eptesicus_forest_collab
[XVEBW] 2016/05/26 16:02:35.613867 model.go:756: INFO: Connection to G7PJ4UV closed: switching connections
[XVEBW] 2016/05/26 16:02:36.037891 model.go:756: INFO: Connection to G7PJ4UV closed: write tcp 10.160.95.179:55580->199.15.254.138:443: use of closed network connection
[XVEBW] 2016/05/26 16:02:38.037005 service.go:158: INFO: Failed to exchange Hello messages with 44HMFSN (108.31.56.174:22000): read tcp 10.160.95.179:55617->108.31.56.174:22000: i/o timeout
[XVEBW] 2016/05/26 16:02:38.224016 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Local Area Connection finished.
[XVEBW] 2016/05/26 16:02:38.231016 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Local Area Connection finished.
[XVEBW] 2016/05/26 16:02:38.237017 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1 finished.
[XVEBW] 2016/05/26 16:02:38.241017 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1 finished.
[XVEBW] 2016/05/26 16:02:38.241017 service.go:61: INFO: Detected 0 NAT devices
[XVEBW] 2016/05/26 16:02:38.776047 static.go:92: INFO: Joined relay relay://104.233.126.133:22067
[XVEBW] 2016/05/26 16:03:20.448431 service.go:229: INFO: Established secure connection to G7PJ4UV at 10.160.95.179:55669-104.233.126.133:22067 (Relay (Server))
[XVEBW] 2016/05/26 16:03:20.448431 model.go:1044: INFO: Device G7PJ4UV client is "syncthing v0.13.4" named "killerdeathman"
[XVEBW] 2016/05/26 16:04:30.792454 model.go:756: INFO: Connection to 44HMFSN closed: switching connections
[XVEBW] 2016/05/26 16:04:31.261481 model.go:756: INFO: Connection to 44HMFSN closed: write tcp 10.160.95.179:55590->23.92.71.120:443: use of closed network connection
[XVEBW] 2016/05/26 16:04:32.935577 model.go:756: INFO: Connection to 44HMFSN closed: switching connections
[XVEBW] 2016/05/26 16:04:33.369602 service.go:229: INFO: Established secure connection to 44HMFSN at 10.160.95.179:55633-108.31.56.174:22000 (TCP (Client))
[XVEBW] 2016/05/26 16:04:33.371602 model.go:1044: INFO: Device 44HMFSN client is "syncthing v0.13.4" named "pine64"
[XVEBW] 2016/05/26 16:04:37.670848 model.go:756: INFO: Connection to G7PJ4UV closed: switching connections
[XVEBW] 2016/05/26 16:04:40.314999 service.go:158: INFO: Failed to exchange Hello messages with 44HMFSN (108.31.56.174:22000): write tcp 10.160.95.179:55679->108.31.56.174:22000: wsasend: An existing connection was forcibly closed by the remote host.
[XVEBW] 2016/05/26 16:04:40.328000 model.go:756: INFO: Connection to G7PJ4UV closed: read tcp 10.160.95.179:55669->104.233.126.133:22067: use of closed network connection
[XVEBW] 2016/05/26 16:04:48.914491 service.go:229: INFO: Established secure connection to G7PJ4UV at 10.160.95.179:55686-104.171.113.18:10508 (Relay (Client))
[XVEBW] 2016/05/26 16:04:48.914491 model.go:1044: INFO: Device G7PJ4UV client is "syncthing v0.13.4" named "killerdeathman"
[XVEBW] 2016/05/26 16:05:05.701451 model.go:756: INFO: Connection to G7PJ4UV closed: switching connections
[XVEBW] 2016/05/26 16:05:06.448494 service.go:182: INFO: Connected to already connected device (44HMFSN)
[XVEBW] 2016/05/26 16:05:06.448494 model.go:756: INFO: Connection to G7PJ4UV closed: write tcp 10.160.95.179:55686->104.171.113.18:10508: use of closed network connection
[XVEBW] 2016/05/26 16:05:15.503012 service.go:229: INFO: Established secure connection to G7PJ4UV at 10.160.95.179:55692-104.233.126.133:22067 (Relay (Server))
[XVEBW] 2016/05/26 16:05:15.503012 model.go:1044: INFO: Device G7PJ4UV client is "syncthing v0.13.4" named "killerdeathman"
HOME - behind router with UPnP:
[G7PJ4] 14:16:35 INFO: syncthing v0.13.4 "Copper Cockroach" (go1.6.2 windows-amd64) WIN-P6RP886TVDJ\Administrator@WIN-P6RP886TVDJ 2016-05-26 09:16:08 UTC
[G7PJ4] 14:16:35 INFO: My ID: G7PJ4UV
[G7PJ4] 14:16:36 INFO: Single thread hash performance is ~162 MB/s
[G7PJ4] 14:16:43 INFO: Ready to synchronize nhwhg_collab (readwrite)
[G7PJ4] 14:16:46 INFO: Ready to synchronize small_space_beampattern (readwrite)
[G7PJ4] 14:16:47 INFO: Ready to synchronize Videos (readonly)
[G7PJ4] 14:16:53 INFO: Ready to synchronize eptesicus_forest_collab (readwrite)
[G7PJ4] 14:16:53 INFO: Using discovery server https://discovery-v4-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 14:16:53 INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 14:16:53 INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 14:16:53 INFO: Using discovery server https://discovery-v6-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 14:16:53 INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 14:16:53 INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 14:16:53 INFO: TCP listener ([::]:22001) starting
[G7PJ4] 14:16:53 INFO: Device G7PJ4UV is "killerdeathman" at [dynamic]
[G7PJ4] 14:16:53 INFO: Device XVEBWC6 is "fuscination" at [dynamic]
[G7PJ4] 14:16:53 INFO: Device 44HMFSN is "pine64" at [dynamic]
[G7PJ4] 14:16:53 INFO: Starting usage reporting
[G7PJ4] 14:16:53 INFO: GUI and API listening on 127.0.0.1:8384
[G7PJ4] 14:16:53 INFO: Access the GUI via the following URL: http://localhost:8384/
[G7PJ4] 14:16:54 INFO: Completed initial scan (ro) of folder Videos
[G7PJ4] 14:17:04 INFO: New NAT port mapping: external TCP address 192.168.1.2:2665 to local address 0.0.0.0:22001.
[G7PJ4] 14:17:04 INFO: Detected 2 NAT devices
[G7PJ4] 14:17:12 INFO: Completed initial scan (rw) of folder small_space_beampattern
[G7PJ4] 14:17:18 INFO: Established secure connection to 44HMFSN at [fe80::1c72:7b46:95bd:afce%Ethernet]:54996-[fe80::d02f:97ff:fe79:2820%Ethernet]:22000 (TCP (Client))
[G7PJ4] 14:17:18 INFO: Device 44HMFSN client is "syncthing v0.13.4" named "pine64"
[G7PJ4] 14:17:20 INFO: Connected to already connected device (44HMFSN)
[G7PJ4] 14:17:26 INFO: Completed initial scan (rw) of folder nhwhg_collab
[G7PJ4] 14:17:30 INFO: Completed initial scan (rw) of folder eptesicus_forest_collab
[G7PJ4] 14:24:31 INFO: TCP listener ([::]:22000) starting
[G7PJ4] 14:24:43 INFO: Joined relay relay://199.15.254.138:443
[G7PJ4] 14:26:48 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:55386-199.15.254.138:443 (Relay (Server))
[G7PJ4] 14:26:48 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 14:27:56 INFO: Connection to XVEBWC6 closed: EOF
[G7PJ4] 15:22:39 INFO: syncthing v0.13.4 "Copper Cockroach" (go1.6.2 windows-amd64) WIN-P6RP886TVDJ\Administrator@WIN-P6RP886TVDJ 2016-05-26 09:16:08 UTC
[G7PJ4] 15:22:39 INFO: My ID: G7PJ4UV
[G7PJ4] 15:22:39 INFO: Single thread hash performance is ~158 MB/s
[G7PJ4] 15:22:58 INFO: Ready to synchronize nhwhg_collab (readwrite)
[G7PJ4] 15:23:01 INFO: Ready to synchronize small_space_beampattern (readwrite)
[G7PJ4] 15:23:03 INFO: Ready to synchronize Videos (readonly)
[G7PJ4] 15:23:08 INFO: Ready to synchronize eptesicus_forest_collab (readwrite)
[G7PJ4] 15:23:08 INFO: Using discovery server https://discovery-v4-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 15:23:08 INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 15:23:08 INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 15:23:08 INFO: Using discovery server https://discovery-v6-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 15:23:08 INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 15:23:08 INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 15:23:08 INFO: TCP listener ([::]:22000) starting
[G7PJ4] 15:23:08 INFO: Device G7PJ4UV is "killerdeathman" at [dynamic]
[G7PJ4] 15:23:08 INFO: Device XVEBWC6 is "fuscination" at [dynamic]
[G7PJ4] 15:23:08 INFO: Device 44HMFSN is "pine64" at [dynamic]
[G7PJ4] 15:23:08 INFO: Starting usage reporting
[G7PJ4] 15:23:08 INFO: GUI and API listening on 127.0.0.1:8384
[G7PJ4] 15:23:08 INFO: Access the GUI via the following URL: http://localhost:8384/
[G7PJ4] 15:23:10 INFO: Completed initial scan (ro) of folder Videos
[G7PJ4] 15:23:19 INFO: Joined relay relay://104.171.113.18:10508
[G7PJ4] 15:23:19 INFO: New NAT port mapping: external TCP address 192.168.1.2:5877 to local address 0.0.0.0:22000.
[G7PJ4] 15:23:19 INFO: Detected 2 NAT devices
[G7PJ4] 15:23:34 INFO: Completed initial scan (rw) of folder small_space_beampattern
[G7PJ4] 15:23:38 INFO: Established secure connection to 44HMFSN at [fe80::1c72:7b46:95bd:afce%Ethernet]:50050-[fe80::d02f:97ff:fe79:2820%Ethernet]:22000 (TCP (Client))
[G7PJ4] 15:23:38 INFO: Device 44HMFSN client is "syncthing v0.13.4" named "pine64"
[G7PJ4] 15:23:53 INFO: Completed initial scan (rw) of folder nhwhg_collab
[G7PJ4] 15:24:07 INFO: Completed initial scan (rw) of folder eptesicus_forest_collab
[G7PJ4] 15:30:10 INFO: Shutting down
[G7PJ4] 15:30:10 INFO: Exiting
[G7PJ4] 15:31:05 INFO: syncthing v0.13.4 "Copper Cockroach" (go1.6.2 windows-amd64) WIN-P6RP886TVDJ\Administrator@WIN-P6RP886TVDJ 2016-05-26 09:16:08 UTC
[G7PJ4] 15:31:05 INFO: My ID: G7PJ4UV
[G7PJ4] 15:31:05 INFO: Single thread hash performance is ~161 MB/s
[G7PJ4] 15:31:08 INFO: Ready to synchronize Videos (readonly)
[G7PJ4] 15:31:13 INFO: Ready to synchronize eptesicus_forest_collab (readwrite)
[G7PJ4] 15:31:18 INFO: Ready to synchronize nhwhg_collab (readwrite)
[G7PJ4] 15:31:21 INFO: Ready to synchronize small_space_beampattern (readwrite)
[G7PJ4] 15:31:21 INFO: Using discovery server https://discovery-v4-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 15:31:21 INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 15:31:21 INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 15:31:21 INFO: Using discovery server https://discovery-v6-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 15:31:21 INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 15:31:21 INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 15:31:21 INFO: TCP listener ([::]:22000) starting
[G7PJ4] 15:31:21 INFO: Device G7PJ4UV is "killerdeathman" at [dynamic]
[G7PJ4] 15:31:21 INFO: Device XVEBWC6 is "fuscination" at [dynamic]
[G7PJ4] 15:31:21 INFO: Device 44HMFSN is "pine64" at [dynamic]
[G7PJ4] 15:31:21 INFO: Starting usage reporting
[G7PJ4] 15:31:21 INFO: GUI and API listening on 127.0.0.1:8384
[G7PJ4] 15:31:21 INFO: Access the GUI via the following URL: http://localhost:8384/
[G7PJ4] 15:31:21 INFO: Completed initial scan (ro) of folder Videos
[G7PJ4] 15:31:32 INFO: Joined relay relay://199.15.254.138:443
[G7PJ4] 15:31:32 INFO: New NAT port mapping: external TCP address 192.168.1.2:5877 to local address 0.0.0.0:22000.
[G7PJ4] 15:31:32 INFO: Detected 2 NAT devices
[G7PJ4] 15:31:39 INFO: Completed initial scan (rw) of folder small_space_beampattern
[G7PJ4] 15:31:50 INFO: Completed initial scan (rw) of folder nhwhg_collab
[G7PJ4] 15:31:54 INFO: Established secure connection to 44HMFSN at [fe80::1c72:7b46:95bd:afce%Ethernet]:50356-[fe80::d02f:97ff:fe79:2820%Ethernet]:22000 (TCP (Client))
[G7PJ4] 15:31:54 INFO: Device 44HMFSN client is "syncthing v0.13.4" named "pine64"
[G7PJ4] 15:31:54 INFO: Completed initial scan (rw) of folder eptesicus_forest_collab
[G7PJ4] 15:34:16 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50378-199.15.254.138:443 (Relay (Server))
[G7PJ4] 15:34:16 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:34:22 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50378->199.15.254.138:443: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 15:34:25 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50380-199.15.254.138:443 (Relay (Server))
[G7PJ4] 15:34:25 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:35:51 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50380->199.15.254.138:443: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 15:35:51 INFO: Connected to already connected device (XVEBWC6)
[G7PJ4] 15:35:55 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50389-199.15.254.138:443 (Relay (Server))
[G7PJ4] 15:35:55 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:37:05 INFO: Connection to XVEBWC6 closed: unexpected EOF
[G7PJ4] 15:37:56 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50408-192.99.235.194:22067 (Relay (Client))
[G7PJ4] 15:37:56 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:38:17 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50408->192.99.235.194:22067: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 15:46:05 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50512-199.15.254.138:443 (Relay (Server))
[G7PJ4] 15:46:05 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:46:22 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50512->199.15.254.138:443: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 15:47:55 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50531-192.99.235.194:22067 (Relay (Client))
[G7PJ4] 15:47:55 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:48:41 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50531->192.99.235.194:22067: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 15:56:16 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50599-199.15.254.138:443 (Relay (Server))
[G7PJ4] 15:56:16 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:56:43 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50599->199.15.254.138:443: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 15:58:05 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50618-192.99.235.194:22067 (Relay (Client))
[G7PJ4] 15:58:05 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 15:59:48 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50618->192.99.235.194:22067: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 16:02:34 INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50701-199.15.254.138:443 (Relay (Server))
[G7PJ4] 16:02:34 INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 16:02:38 INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50701->199.15.254.138:443: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 16:03:02 INFO: Enabled debug data for "nat"
[G7PJ4] 16:03:02 INFO: Enabled debug data for "upnp"
[G7PJ4] 16:03:08 INFO: Restarting
[G7PJ4] 16:03:08 INFO: Exiting
[G7PJ4] 2016/05/26 16:03:09.140553 main.go:561: INFO: syncthing v0.13.4 "Copper Cockroach" (go1.6.2 windows-amd64) WIN-P6RP886TVDJ\Administrator@WIN-P6RP886TVDJ 2016-05-26 09:16:08 UTC
[G7PJ4] 2016/05/26 16:03:09.142053 main.go:562: INFO: My ID: G7PJ4UV
[G7PJ4] 2016/05/26 16:03:09.446092 main.go:853: INFO: Single thread hash performance is ~162 MB/s
[G7PJ4] 2016/05/26 16:03:11.019791 model.go:209: INFO: Ready to synchronize Videos (readonly)
[G7PJ4] 2016/05/26 16:03:15.735605 model.go:209: INFO: Ready to synchronize eptesicus_forest_collab (readwrite)
[G7PJ4] 2016/05/26 16:03:19.367675 model.go:209: INFO: Ready to synchronize nhwhg_collab (readwrite)
[G7PJ4] 2016/05/26 16:03:21.690072 model.go:209: INFO: Ready to synchronize small_space_beampattern (readwrite)
[G7PJ4] 2016/05/26 16:03:21.690072 main.go:705: INFO: Using discovery server https://discovery-v4-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 2016/05/26 16:03:21.690072 main.go:705: INFO: Using discovery server https://discovery-v4-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 2016/05/26 16:03:21.690572 main.go:705: INFO: Using discovery server https://discovery-v4-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 2016/05/26 16:03:21.691072 tcp_listen.go:69: INFO: TCP listener ([::]:22000) starting
[G7PJ4] 2016/05/26 16:03:22.281147 main.go:705: INFO: Using discovery server https://discovery-v6-1.syncthing.net/v2/?id=SR7AARM
[G7PJ4] 2016/05/26 16:03:22.281147 main.go:705: INFO: Using discovery server https://discovery-v6-2.syncthing.net/v2/?id=DVU36WY
[G7PJ4] 2016/05/26 16:03:22.281147 main.go:705: INFO: Using discovery server https://discovery-v6-3.syncthing.net/v2/?id=VK6HNJ3
[G7PJ4] 2016/05/26 16:03:22.304150 main.go:750: INFO: Device G7PJ4UV is "killerdeathman" at [dynamic]
[G7PJ4] 2016/05/26 16:03:22.306150 main.go:750: INFO: Device XVEBWC6 is "fuscination" at [dynamic]
[G7PJ4] 2016/05/26 16:03:22.306651 main.go:750: INFO: Device 44HMFSN is "pine64" at [dynamic]
[G7PJ4] 2016/05/26 16:03:22.307151 usage_report.go:264: INFO: Starting usage reporting
[G7PJ4] 2016/05/26 16:03:22.320152 gui.go:347: INFO: GUI and API listening on 127.0.0.1:8384
[G7PJ4] 2016/05/26 16:03:22.320152 gui.go:348: INFO: Access the GUI via the following URL: http://localhost:8384/
[G7PJ4] 2016/05/26 16:03:22.692699 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Ethernet
[G7PJ4] 2016/05/26 16:03:22.693199 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Teredo Tunneling Pseudo-Interface
[G7PJ4] 2016/05/26 16:03:22.694699 upnp.go:154: DEBUG: listen udp4 0.0.0.0:52749->239.255.255.250: setsockopt: no such network interface
[G7PJ4] 2016/05/26 16:03:22.694699 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Ethernet
[G7PJ4] 2016/05/26 16:03:22.695699 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Ethernet
[G7PJ4] 2016/05/26 16:03:22.695699 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Teredo Tunneling Pseudo-Interface
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:154: DEBUG: listen udp4 0.0.0.0:52751->239.255.255.250: setsockopt: no such network interface
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on isatap.{6482FEF5-1A87-48D5-80EF-46E642D80C4F}
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on isatap.{6482FEF5-1A87-48D5-80EF-46E642D80C4F}
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Ethernet
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Ethernet
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:150: DEBUG: Starting discovery of device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1
[G7PJ4] 2016/05/26 16:03:22.697200 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Ethernet
[G7PJ4] 2016/05/26 16:03:22.728204 upnp.go:154: DEBUG: listen udp4 0.0.0.0:52752->239.255.255.250: setsockopt: no such network interface
[G7PJ4] 2016/05/26 16:03:22.731705 upnp.go:154: DEBUG: listen udp4 0.0.0.0:52753->239.255.255.250: setsockopt: no such network interface
[G7PJ4] 2016/05/26 16:03:22.736205 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1
[G7PJ4] 2016/05/26 16:03:22.737705 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1
[G7PJ4] 2016/05/26 16:03:22.740706 upnp.go:165: DEBUG: Sending search request for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1
[G7PJ4] 2016/05/26 16:03:22.741206 upnp.go:173: DEBUG: Listening for UPnP response for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1
[G7PJ4] 2016/05/26 16:03:22.748706 upnp.go:196: DEBUG: Handling UPnP response:
HTTP/1.1 200 OK
CACHE-CONTROL: max-age=120
ST: urn:schemas-upnp-org:device:InternetGatewayDevice:1
USN: uuid:0bb7e645-02c6-40f3-8954-48297866d2eb::urn:schemas-upnp-org:device:InternetGatewayDevice:1
EXT:
SERVER: AsusWRT/380.58 UPnP/1.1 MiniUPnPd/1.9
OPT: "http://schemas.upnp.org/upnp/1/0/"; ns=01
01-NLS: 1464283356
BOOTID.UPNP.ORG: 1464283356
CONFIGID.UPNP.ORG: 1337
[G7PJ4] 2016/05/26 16:03:22.750706 upnp.go:196: DEBUG: Handling UPnP response:
HTTP/1.1 200 OK
ST: urn:schemas-upnp-org:device:InternetGatewayDevice:2
USN: uuid:0bb7e645-02c6-40f3-8954-48297866d2eb::urn:schemas-upnp-org:device:InternetGatewayDevice:2
EXT:
01-NLS: 1464283356
[G7PJ4] 2016/05/26 16:03:22.754207 upnp.go:354: DEBUG: http://192.168.11.1:49329/rootDesc.xml - no services of type urn:schemas-upnp-org:service:WANIPConnection:1 found on connection.
[G7PJ4] 2016/05/26 16:03:22.754207 upnp.go:363: DEBUG: http://192.168.11.1:49329/rootDesc.xml - found urn:schemas-upnp-org:service:WANIPConnection:1 with URL http://192.168.11.1:49329/ctl/IPConn
[G7PJ4] 2016/05/26 16:03:22.754207 upnp.go:354: DEBUG: http://192.168.11.1:49329/rootDesc.xml - no services of type urn:schemas-upnp-org:service:WANPPPConnection:1 found on connection.
[G7PJ4] 2016/05/26 16:03:22.755207 upnp.go:354: DEBUG: http://192.168.11.1:49329/rootDesc.xml - no services of type urn:schemas-upnp-org:service:WANIPConnection:1 found on connection.
[G7PJ4] 2016/05/26 16:03:22.755207 upnp.go:363: DEBUG: http://192.168.11.1:49329/rootDesc.xml - found urn:schemas-upnp-org:service:WANIPConnection:1 with URL http://192.168.11.1:49329/ctl/IPConn
[G7PJ4] 2016/05/26 16:03:22.755707 upnp.go:354: DEBUG: http://192.168.11.1:49329/rootDesc.xml - no services of type urn:schemas-upnp-org:service:WANPPPConnection:1 found on connection.
[G7PJ4] 2016/05/26 16:03:22.786711 upnp.go:124: DEBUG: UPnP discovery result 0bb7e645-02c6-40f3-8954-48297866d2eb with services:
[G7PJ4] 2016/05/26 16:03:22.786711 upnp.go:126: DEBUG: * [urn:upnp-org:serviceId:WANIPConn1] http://192.168.11.1:49329/ctl/IPConn
[G7PJ4] 2016/05/26 16:03:22.789711 upnp.go:115: DEBUG: Skipping duplicate result 0bb7e645-02c6-40f3-8954-48297866d2eb with services:
[G7PJ4] 2016/05/26 16:03:22.789711 upnp.go:117: DEBUG: * [urn:upnp-org:serviceId:WANIPConn1] http://192.168.11.1:49329/ctl/IPConn
[G7PJ4] 2016/05/26 16:03:22.825216 rofolder.go:79: INFO: Completed initial scan (ro) of folder Videos
[G7PJ4] 2016/05/26 16:03:22.911727 service.go:229: INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50729-104.233.126.133:22067 (Relay (Client))
[G7PJ4] 2016/05/26 16:03:22.911727 model.go:1044: INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 2016/05/26 16:03:32.696272 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Ethernet finished.
[G7PJ4] 2016/05/26 16:03:32.697272 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Ethernet finished.
[G7PJ4] 2016/05/26 16:03:32.736277 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:1 on Loopback Pseudo-Interface 1 finished.
[G7PJ4] 2016/05/26 16:03:32.741277 upnp.go:192: DEBUG: Discovery for device type urn:schemas-upnp-org:device:InternetGatewayDevice:2 on Loopback Pseudo-Interface 1 finished.
[G7PJ4] 2016/05/26 16:03:32.741277 service.go:264: DEBUG: Acquiring TCP 0.0.0.0:22000 mapping on NAT-PMP@192.168.11.1
[G7PJ4] 2016/05/26 16:03:32.757780 service.go:272: DEBUG: Acquired TCP 0.0.0.0:22000 -> 192.168.1.2:5877 mapping on NAT-PMP@192.168.11.1
[G7PJ4] 2016/05/26 16:03:32.757780 structs.go:32: INFO: New NAT port mapping: external TCP address 192.168.1.2:5877 to local address 0.0.0.0:22000.
[G7PJ4] 2016/05/26 16:03:32.757780 service.go:264: DEBUG: Acquiring TCP 0.0.0.0:22000 mapping on 0bb7e645-02c6-40f3-8954-48297866d2eb
[G7PJ4] 2016/05/26 16:03:32.757780 upnp.go:423: DEBUG: SOAP Request URL: http://192.168.11.1:49329/ctl/IPConn
[G7PJ4] 2016/05/26 16:03:32.757780 upnp.go:424: DEBUG: SOAP Action:
[G7PJ4] 2016/05/26 16:03:32.757780 upnp.go:425: DEBUG: SOAP Request:
<?xml version="1.0" ?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
<s:Body><u:AddPortMapping xmlns:u="urn:schemas-upnp-org:service:WANIPConnection:1">
<NewRemoteHost></NewRemoteHost>
<NewExternalPort>5877</NewExternalPort>
<NewProtocol>TCP</NewProtocol>
<NewInternalPort>22000</NewInternalPort>
<NewInternalClient>192.168.11.51</NewInternalClient>
<NewEnabled>1</NewEnabled>
<NewPortMappingDescription>syncthing-5877</NewPortMappingDescription>
<NewLeaseDuration>3600</NewLeaseDuration>
</u:AddPortMapping></s:Body>
</s:Envelope>
[G7PJ4] 2016/05/26 16:03:32.760780 upnp.go:434: DEBUG: SOAP Response: 200 OK
<?xml version="1.0"?>
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:AddPortMappingResponse xmlns:u="urn:schemas-upnp-org:service:WANIPConnection:1"/></s:Body></s:Envelope>
[G7PJ4] 2016/05/26 16:03:32.761279 upnp.go:423: DEBUG: SOAP Request URL: http://192.168.11.1:49329/ctl/IPConn
[G7PJ4] 2016/05/26 16:03:32.761279 upnp.go:424: DEBUG: SOAP Action:
[G7PJ4] 2016/05/26 16:03:32.761279 upnp.go:425: DEBUG: SOAP Request:
<s:Body><u:GetExternalIPAddress xmlns:u="urn:schemas-upnp-org:service:WANIPConnection:1" /></s:Body>
</s:Envelope>
[G7PJ4] 2016/05/26 16:03:32.762780 upnp.go:434: DEBUG: SOAP Response: 200 OK
<s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><u:GetExternalIPAddressResponse xmlns:u="urn:schemas-upnp-org:service:WANIPConnection:1"><NewExternalIPAddress>192.168.1.2</NewExternalIPAddress></u:GetExternalIPAddressResponse></s:Body></s:Envelope>
[G7PJ4] 2016/05/26 16:03:32.762780 service.go:272: DEBUG: Acquired TCP 0.0.0.0:22000 -> 192.168.1.2:5877 mapping on 0bb7e645-02c6-40f3-8954-48297866d2eb
[G7PJ4] 2016/05/26 16:03:32.762780 structs.go:32: INFO: New NAT port mapping: external TCP address 192.168.1.2:5877 to local address 0.0.0.0:22000.
[G7PJ4] 2016/05/26 16:03:32.762780 service.go:61: INFO: Detected 2 NAT devices
[G7PJ4] 2016/05/26 16:03:33.778014 static.go:92: INFO: Joined relay relay://104.171.113.18:10508
[G7PJ4] 2016/05/26 16:04:02.119044 rwfolder.go:307: INFO: Completed initial scan (rw) of folder small_space_beampattern
[G7PJ4] 2016/05/26 16:04:29.914015 rwfolder.go:307: INFO: Completed initial scan (rw) of folder nhwhg_collab
[G7PJ4] 2016/05/26 16:04:37.200144 service.go:158: INFO: Failed to exchange Hello messages with 44HMFSN (192.168.11.53:36492): read tcp 192.168.11.51:22000->192.168.11.53:36492: i/o timeout
[G7PJ4] 2016/05/26 16:04:37.786718 rwfolder.go:307: INFO: Completed initial scan (rw) of folder eptesicus_forest_collab
[G7PJ4] 2016/05/26 16:04:39.201002 service.go:158: INFO: Failed to exchange Hello messages with 44HMFSN ([fe80::d02f:97ff:fe79:2820%Ethernet]:22000): read tcp [fe80::1c72:7b46:95bd:afce%Ethernet]:50859->[fe80::d02f:97ff:fe79:2820%Ethernet]:22000: i/o timeout
[G7PJ4] 2016/05/26 16:04:42.863033 model.go:756: INFO: Connection to XVEBWC6 closed: EOF
[G7PJ4] 2016/05/26 16:04:51.477372 service.go:229: INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50917-104.171.113.18:10508 (Relay (Server))
[G7PJ4] 2016/05/26 16:04:51.477873 model.go:1044: INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 2016/05/26 16:05:01.295039 service.go:229: INFO: Established secure connection to 44HMFSN at [fe80::1c72:7b46:95bd:afce%Ethernet]:50920-[fe80::d02f:97ff:fe79:2820%Ethernet]:22000 (TCP (Client))
[G7PJ4] 2016/05/26 16:05:01.295039 model.go:1044: INFO: Device 44HMFSN client is "syncthing v0.13.4" named "pine64"
[G7PJ4] 2016/05/26 16:05:10.125964 model.go:756: INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50917->104.171.113.18:10508: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 2016/05/26 16:05:17.970681 service.go:229: INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50923-104.233.126.133:22067 (Relay (Client))
[G7PJ4] 2016/05/26 16:05:17.971182 model.go:1044: INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 2016/05/26 16:06:22.492077 model.go:756: INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50923->104.233.126.133:22067: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 2016/05/26 16:06:52.558984 service.go:229: INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50940-104.233.126.133:22067 (Relay (Client))
[G7PJ4] 2016/05/26 16:06:52.558984 model.go:1044: INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 2016/05/26 16:07:35.020714 model.go:756: INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50940->104.233.126.133:22067: wsasend: An existing connection was forcibly closed by the remote host.
[G7PJ4] 2016/05/26 16:08:39.773201 service.go:229: INFO: Established secure connection to XVEBWC6 at 192.168.11.51:50951-104.171.113.18:10508 (Relay (Server))
[G7PJ4] 2016/05/26 16:08:39.773702 model.go:1044: INFO: Device XVEBWC6 client is "syncthing v0.13.4" named "fuscination"
[G7PJ4] 2016/05/26 16:09:53.508136 model.go:756: INFO: Connection to XVEBWC6 closed: write tcp 192.168.11.51:50951->104.171.113.18:10508: wsasend: An existing connection was forcibly closed by the remote host.
So the work logs are not of interest to us.
Do you run the router at home behind another router? Because it’s reporting it’s external IP as 192.168.1.2
Yes behind another router. The internet topology has not changed though. I have the second router set as DMZ.
In 0.13 we’ve started reporting the external address that the router reports, so that’s your issue.
But I’ve made a pull request which although does the wrong thing, but brings the functionality back:
Thank you very much!
I’m just curious, why wouldn’t you use a service to pull down the external address?
The discovery servers already know this, it’s just that arguably the router should be more correct, as it’s aware of how the routing should be performed.
