I am syncing 2 win 7 x32 machins on local network.
One of the machins did not have login password & sincing was worknig fine.
After I added password to the passwordless machine syncing atopped.
I took the new Device ID to the other machine and added the “with new password” machin’s
New Device ID.
Then I tried to “Remove” the old Remote Device from the list
Nothing happens - It reappears after refreshing the brawser.
The UI can’t work without syncthing running.
The panic might be something todo with how the build the 32bit versions. Are you sure you cannot use 64 bit version?
Anyways, if web ui is available, syncthing should be visible in the task manager.
Yes - The Page reload when I refresh.
No - Only one user on both sides.
( the HOME side is the nothing changed side. - the BIG-TV side is where I changed the password from blank )
