UFW blocks tcp-connection
Hi!
I started using syncthing just few days ago. I have two linux computers with UFW blocking anything but my VPN connections. I allowed syncthing and also ports 22000 and 21027 (just to make sure) for UFW. I have also forwarded the port 22000 from my router and VPN settings. Syncthing still doesn’t connect to tcp-server, but only to relay-server. Did I forget something? It also doesn’t connect to my android device at all. When UFW is turned off everything works just fine. In the web interface the discovery is 3/8.
You probably need to allow the ports both ways, as you are probably allowing outbound traffic and not inbound.
Allowing syncthing allows inbound, but not outbound.
To                         Action      From
22000/tcp (syncthing)      ALLOW IN    Anywhere
21027/udp (syncthing)      ALLOW IN    Anywhere
This is from daemon output. I tried allowing 239.255.255.250 from UFW, but no change.
[NLJ33] 13:35:57 INFO: write udp4 0.0.0.0:52006->239.255.255.250:1900: sendto: operation not permitted
[NLJ33] 13:35:57 INFO: write udp4 0.0.0.0:53971->239.255.255.250:1900: sendto: operation not permitted
[NLJ33] 13:35:57 INFO: write udp4 0.0.0.0:54367->239.255.255.250:1900: sendto: operation not permitted
[NLJ33] 13:35:57 INFO: write udp4 0.0.0.0:53714->239.255.255.250:1900: sendto: operation not permitted
Have you verified that when you allow, the firewall actually allows, and not just says it does?
Yes with
ufw status verbose
is there other way to check it?
You can try using a different networked application on the same port.
Seems to be open:
sudo netstat -anp | grep 21027
udp        0      0 0.0.0.0:21027           0.0.0.0:*                           618/syncthing
udp6       0      0 :::21027                :::*                                618/syncthing
and
sudo netstat -anp | grep 22000
tcp6       0      0 :::22000                :::*                    LISTEN      618/syncthing
This doesn’t mean much, it just shows that it’s listening, but that doesn’t mean the kernel lets the traffic through. Best if you do some sort of netcat test.
Thanks, I’m quite new on these internet-things. But I got it solved. Apparently allow syncthing won’t allow outbound connections. So allowing outbound connections for the ports manually made it work. Thank you for getting me on the right track!
