sirhaffy
(Fredrik Svärd)
May 31, 2023, 10:53am
1
I am trying to use an OWC 10GB thunderbolt 3 adapter for synching, it works for everything else but not synching. I have tried with other OWC network interfaces too (have no other to test with here), but the same thing there. Are there som settings I can play with?
I have restarted both computers.
sirhaffy
(Fredrik Svärd)
May 31, 2023, 11:17am
2
Ok, now it won’t sync on wifi any more ether.
bt90
(Bt90)
May 31, 2023, 5:08pm
3
Could you describe your network a bit more? Do you have multiple interfaces connected to the same network?
sirhaffy
(Fredrik Svärd)
June 1, 2023, 1:15pm
4
Yes in a way, I have Wireless and a Ethernet interface connected. But Ethernet is on higher priority (Mac). So it should only use the Ethernet.
I think the priority is a OS thing, applications don’t care much. They just connect, and OS decides which adapter the connection goes out through.
system
(system)
Closed
July 1, 2023, 6:51pm
6
