systemd trouble after v1.1.1 upgrade
I’ve been using syncthing on my Ubuntu server (now 18.04 LTS) for years. With the v1.1.1 upgrade, my install stopped working.
After a reboot, systemd reports:
● syncthing@acr.service - Syncthing - Open Source Continuous File Synchronization for acr
Loaded: loaded (/lib/systemd/system/syncthing@.service; indirect; vendor preset: enabled)
Active: inactive (dead)
Docs: man:syncthing(1)
If I try to restart the service
sudo systemctl restart syncthing@acr.service
it hangs the terminal window (and the service does not start). I tried to look over the systemd logs using journald (using journalctl -e -u syncthing@acr.service) but the last entries are from the v1.1.0 install.
I have also tried disabling and re-enabling the service with those systemctl commands.
Incidentally, if I just start syncthing from the command line, everything looks good.
How shall I proceed?
P.s. Thank you for this awesome software.
The only thing that changed was, that there is now a After dependency on multi-user.target, but that should be a non-issue. It seems “wrong” to use restart instead of start when the service isn’t running, but that shouldn’t cause hanging either. So in the end I have no clue what might be going on.
Very mysterious.
I’ve just downgraded to v1.1.0 and everything works now. (I used apt to uninstall and then reinstall the old version.)
If there is something I could do to help identify this bug, let me know. In the meantime, I will hope that someone with better systemd skills will run into the same problem and figure out what’s up.
Same problem here, also 18.04, I can confirm the observations. I didn’t make any changes to my config, so it must be related to the upgrade. Unfortunately, no clue either :confused:
Okay there’s a clue now, removing the multiuser after dependency does the trick.
I’m no systemd expert, but maybe that is the issue: When enabling the syncthing service, I get the output
$ sudo systemctl enable syncthing@linus.service
Created symlink /etc/systemd/system/multi-user.target.wants/syncthing@linus.service → /lib/systemd/system/syncthing@.service
Does that mean multiuser already depends on syncthing and we get a circular dependency?
Sounds like it! Our unit file:
[Install]
WantedBy=multi-user.target
This seems like a logic error, maybe saved by earlier versions of systemd not actually implementing logic. We should revert that latest change I think.
Someone mind filing an official bug on this on our tracker on GitHub to motivate the change?
Sure, will do :slight_smile:
Edit: For reference, see Systemd circular dependency prevents startup · Issue #5676 · syncthing/syncthing · GitHub
As mentioned on that issue, but for the audience here,
I’m actually pulling this into 1.1.2 even though it’s very late in the cycle. I think this is justified by 1) it being a serious issue that blocks startup of syncthing and 2) the fix being a revert to a previously tested and known good (enough) setup.
I don’t plan to make another 1.1.2 RC for this.
Thanks @lseelinger for figuring it out.
