Greetings,
I have a Master (send only) Folder that is being deleted however the remote folder is not being subsequently delete even although both folders are in sync, instead I been getting these messages endlessly repeated in the syslog…
Jan 11 21:37:32 ubuntu syncthing[19617]: [2AIRP] INFO: Puller (folder “rm3ic-trrs”, dir “xxx”): delete: remove /mnt/syncthing/finished/yyy/xxx: directory not empty Jan 11 21:37:33 ubuntu syncthing[19617]: message repeated 10 times: [ [2AIRP] INFO: Puller (folder “rm3ic-trrs”, dir “xxxx”): delete: remove /mnt/syncthing/finished/yyy/xxx] Jan 11 21:37:33 ubuntu syncthing[19617]: [2AIRP] INFO: Folder “rm3ic-trrs” isn’t making progress. Pausing puller for 1m0s.
I suspect the issue is due to a .ignore file thus is why syncthing is not deleting the directory instead it endlessly tries to…
Clearly I can ignore the delete via advanced settings which is not ideal as I will now need to manually delete the directory instead can we add a new advanced flag force delete directory?
Thanks!
