Hi, Is there is a way to disabled the build in tool to help you resolve file conflicts.
Tks. Sam
Tks. Sam
No. What problem are you trying to solve?
Searching for cpu “excessive” usage. (more than 3To on 50 devices)
Which process is showing the high CPU usage?
Syncthing.
I have sometimes this message 2019-04-29 10:29:36:
Decoding posted config: read tcp 127.0.0.1:8384->127.0.0.1:65292: i/o timeout
I/O or hard drive is full ?
Regards Sam
Slow machine most likely
OK, thanks @all
Right, so high cpu usage in Syncthing has nothing to do with anything in SyncTrayzor, especially not the conflict file resolution stuff.
