E-book reader Onyx-Boox MC_Cleopatra3 Android 4.0.4 kernel ver. 3.0.35 jenkins@ubuntu-build-server #1 Fri Jul 21 18:58:40 CST 2017
what happened
Syncthing don’t letting me customize and use itself.
what you expected to happen instead
I’ve expected the same exellent synchronization like on smartphone.
and any steps to reproduce the problem.
It probably be better to show the photoes…
Sorry if I doing something wrong. I just want to be more understandable. Screenshots couldn’t be upload for unknown reasons. I can give a links on them 1. 2. 3. 4. 5. 6.
CatLog output
SyncthingRunnable
04-27 13:53:50.670 I/SyncthingRunnable(3669): Syncthing exited with code 11
04-27 13:53:50.670 W/SyncthingRunnable(3669): Syncthing has crashed (exit code 11)
04-27 13:53:50.890 I/System (3669): at com.nutomic.syncthingandroid.service.SyncthingRunnable.run(SyncthingRunnable.java:152)
04-27 13:53:51.740 I/SyncthingRunnableIoNice(3669): ionice performed on libsyncthing.so
04-27 13:53:51.740 I/System (3669): at com.nutomic.syncthingandroid.service.SyncthingRunnable$1.run(SyncthingRunnable.java:205)
04-27 13:53:51.740 E/SyncthingRunnableIoNice(3669): Failed to set ionice 1
04-27 13:54:48.600 I/SyncthingRunnable(3669): Syncthing exited with code 11
04-27 13:54:48.600 W/SyncthingRunnable(3669): Syncthing has crashed (exit code 11)
04-27 13:54:48.620 I/System (3669): at com.nutomic.syncthingandroid.service.SyncthingRunnable.run(SyncthingRunnable.java:152)
04-27 13:54:49.570 I/SyncthingRunnable(3669): Syncthing exited with code 11
04-27 13:54:49.570 W/SyncthingRunnable(3669): Syncthing has crashed (exit code 11)
04-27 13:54:49.720 I/System (3669): at com.nutomic.syncthingandroid.service.SyncthingRunnable.run(SyncthingRunnable.java:152)
04-27 13:54:49.740 I/SyncthingRunnableIoNice(3669): ionice performed on libsyncthing.so
04-27 13:54:49.740 I/System (3669): at com.nutomic.syncthingandroid.service.SyncthingRunnable$1.run(SyncthingRunnable.java:205)
04-27 13:54:49.740 E/SyncthingRunnableIoNice(3669): Failed to set ionice 1
04-27 13:54:50.530 I/SyncthingRunnableIoNice(3669): ionice performed on libsyncthing.so
04-27 13:54:50.530 I/System (3669): at com.nutomic.syncthingandroid.service.SyncthingRunnable$1.run(SyncthingRunnable.java:205)
04-27 13:54:50.530 E/SyncthingRunnableIoNice(3669): Failed to set ionice 1
SyncthingRunnableloNice
Other log files was empty
Version Information
App Version: hmm.. what App do you mean?
Syncthing Version: v0.10.8
Android Version: Android 4.0.4
Thank You very much for help! Syncthing is very needed and important program for me.
