Syncthing v1.28 will not sync
I have syncthing running on whatbox (v1.27). I had syncthing v1.28 running on my home pc.
files stopped syncing when my homePC auto updated to v1.28.
I consistently got the error : syncing: finishing: pull: generic error
I pulled v1.27.12 from github and restored that on my home pc, then everything started syncing fine again.
You need to remove the password in the Sharing tab in the folder settings. It is only needed if you intend to share the folder and accept it on the other side as “Receive Encrypted”. See https://github.com/syncthing/syncthing/issues/9784 for details.
Unfortunately, one side of the sync is a rented cloud server on whatbox. I don’t have the choice to remove the password. When I do, it says in the password dialog : Device is untrusted, enter encryption password
And I cannot save until I enter a password. The whatbox server is running 1.27.12, and I don’t have the option to upgrade it that I see.
In this case, you first need to go into the Advanced tab in the specific remote device settings and untick the “Untrusted” option.
Thank you!!! That worked perfectly.
