Which one? There are a lot of them.
Maybe I have tried out some earlier build, I don’t remember. Assuming that I did run an earlier dev build, this seems to be not a bug. ![]()
I tried deleting the config.xml.v12 file, but got the same errors.
It reads the config.xml. I suspect this is not-a-bug - you even having a syncthing.xml.v12 is weird, the backup file ought to be called .v11 (as that was the previous config format). v11 format configs do get converted correctly in my tests.
ok. Then this is something weird in my setup; I just convert it manually when 0.12 is out.
Or give it a v11 config - you should be able to just change the number on the first line of config.xml
I can reproduce this.
In previous versions of syncthing I could change “dynamic” to “somehost.example.com” - and I still can in the current beta. But now syncthing reports a “unknown address schema” error.
You need a tcp:// prefix nowadays. That’s what the config conversion adds (among other things).
Yes. Should the gui enforce that?
Maybe
Any value in STTRACE makes line numbers appear.
