Syncthing stuck no WebGUI
I managed to kill my syncthing earlier today; it came up with no config at all.
I started rebuilding the config; I had already added a bunch of folders and syncd them to the appropriate computers.
Then I added two quite large (1.5TB across about 2500files) folders; these were in the old config. With no issue. Now syncthing won’t restart.
I can’t get to the web GUI; and the max uptime (according to top) is about 6 minutes; often resetting before 3 minutes.
Does anyone know what is happening here?
NOTE: CPU usage is 200%+ and RAM usage is around 6GB.
The obvious thing to do is to check the logs
Looks like it has fixed itself.
The old config came back from somewhere??? It took over 3 hours to reappear. I don’t know what happened.
