Hi, I am having currently working on a Saltstack SLS/Setup for Syncthing which will allow for
- Easy deployments
- Easy configuration of syncthing
- Automatic addition of new syncthing nodes to a syncthing cluster
- Automatic firewall configuration (at the moment, CSF supported)
It is still under heavy development.
If anyone wants to test it out, the custom grain and SLS are available at
https://github.com/StartledPhoenix/saltstack-syncthing
At the moment, SLS support is limited to only Ubuntu.
For those who don’t know what Saltstack is: -> http://www.saltstack.com/
Happy Holidays!
After a week of work, the main features seem to be working.
Now supporting
- Automatic addition of syncthing nodes (All syncthing nodes added using this formula will be added to each other)
- Adding syncthing nodes that are non-managed by saltstack
- Basic folder management, you can now assign folders to nodes and they will automatically be added.
Still Undone:
Arch detection (x86/x64), I’m still a bit hesitant to implement this as I have not found a straightforward way to get the latest version downloaded. I still have to make it work with Saltstack’s hash verification or remove it entirely
Advanced folder configuration (ro, stversion, etc)
Firewall systems and IP binding is still a bit wonky. In the configuration im using, I configured it to bind to all ips
Advanced Node configuration (compression, static ip, speed limits)
Oh, and Merry Christmas
