I am having a bit of an issue with how syncthing creates conflicts constantly.
Here is how this is happening.
I have 5 nodes connected to eachother (3 Linux, 2 Android). all running also syncthing-inotify
Only one node(linux) and the same one always creates some playlists every 3 hours via cron job(parsing an writing some mp3s in playlist)
These playlists are "created/modified) by only one node and no other node. Other nodes might read them but that is it.
Every day, after sometime, based on some unknown circumstances, Syncthing populates the folder where the playlists resides with conflict files.
And this is puzzling. Why would Syncthing create conflicts of those playlist files if only one node is writing or modifying them?
It is not like the playlists are written every 5 secs, i would see that might be an issue where updates and other nodes cant catch up with the changes but 3 hours is sufficient to catch up.
I’m a bit of a broken record on this, but the keyword is usually “Android”. I suspect the conflicts, whatever the real cause, happen when one of your Android devices sync.
Ok if we assume that the Android version is the issue, what can we do about this? Is there a workaround, remedy for avoiding conflicts from Android (beside not using it)?
